Electric Field in Capacitors and Diodes
In summary, a diode is a component that allows current to flow from the positive terminal of a power supply to the negative terminal, while a capacitor does not allow this current to flow. The difference between the two devices is due to the PN junction of a diode, which allows for free electrons to flow across the electric field, while the dielectric of a capacitor prevents this from happening.
amenhotep
29
Hello,
Capacitor
When a capacitor is connected to a voltage source, electrons will move from one plate and accumulate in the other in accordance to Q=CV. Due to the imbalance of charges (positive and negative ions) between the plates, an electric field exists that flow in the direction of the more negative plate. If we assume an ideal capacitor (no leakage resistor), the electrons at the negative plate will not flow across the electric field into the positive plate.
Diode
When a p and n semiconductor materials are chemically combined together, initially free electrons in the n material diffuse across the junction into the n material. Without prolonging the story, positive ions in the n material and negative ions in the p material around the junction form an electric field in the direction of the p material. This electric field prevents less energetic electrons in the n material from flowing across junction. For this reason, the negative terminal of a power supply must be connected to the n material to allow current through the diode.
My question
Now, let's see the similarities between the capacitor and diode.
Capacitor -- Diode
+ve plate -- n material
-ve plate -- p material
dielectric -- pn junction
The electric field points from the n (or positive plate of the capacitor) to the p (or negative plate of the capacitor).
In the case of the diode, the p material has minority carriers (few electrons) and these can easily flow across the electric field into the n material. This constitutes the so-called leakage current.
In the case of the capacitor, one should expect something similar, that the electrons on the negative plate should flow across the field because the field is oriented in the same direction as that in the diode. But according to all what I know about capacitors, electrons do not flow across the E field. The question is why not? Why electrons can flow across the E field in a diode (from p to n) and cannot in a capacitor?
Thanks.
The PN junction of a diode is a semiconductor. The dielectric of a capacitor is an insulator.
But why is the pn junction called the depletion region. Doesn't that mean there are no carriers available which implies that pn junction is behaving like an insulator ? An insulator should be a material with no free carriers.
Related to Electric Field in Capacitors and Diodes
1. What is an electric field?
An electric field is a physical quantity that describes the force exerted on a charged particle by other charged particles in its vicinity. It is a vector quantity, meaning it has both magnitude and direction.
2. How is an electric field created in a capacitor?
In a capacitor, an electric field is created by separating two conductive plates with an insulating material, known as a dielectric. The positive and negative charges on the plates create an electric field between them, with the positive charges on one plate attracting negative charges on the other plate.
3. What is the equation for calculating the electric field in a capacitor?
The electric field in a capacitor is given by the equation E = V/d, where E is the electric field strength, V is the potential difference between the plates, and d is the distance between the plates.
4. How does the electric field affect the flow of current in a diode?
In a diode, the electric field plays a crucial role in allowing current to flow in only one direction. When the diode is forward biased, the electric field helps to push electrons from the N-type material to the P-type material, allowing current to flow. When the diode is reverse biased, the electric field prevents the flow of current.
5. Can the electric field in a capacitor or diode be manipulated?
Yes, the electric field in a capacitor can be altered by changing the distance between the plates or the potential difference applied. In a diode, the electric field can be manipulated by changing the material used or the amount of doping in the semiconductor material.
  • Electrical Engineering
  • Electromagnetism
