Electric field in coaxial cable
In summary, the conversation discusses the propagation of TEM waves in a coaxial cable and the discrepancy between this and Ohm's law, which states that current should flow in the same direction as the electric field. The reason for this is due to surface charges and in the ideal case of infinite conductivity, there would be no longitudinal component of the wave.
oocelik
Every physics books show that wave prograpation in coxial cable is TEM wave, like in the picture. But we know that J=σ E from ohms law, which says current in same direction with E field, which is not the case here. What do you think the reason is ?
Hello Dale,
Thank you for the reply. But I am talking about the ideal case where the cable has infinite conductivity and progpagation is pure TEM wave, which makes it sure that there is no "longitudinal" (i.e Ez=0) along the cable by definition. In this case, what force acts on the charges to flow down the cable ?
FAQ: Electric field in coaxial cable
1. What is an electric field in a coaxial cable?
An electric field in a coaxial cable is a region of space where electrically charged particles experience an electric force. In a coaxial cable, the electric field is created by the potential difference between the inner and outer conductors, which allows for the transmission of electric signals.
2. How is the electric field distributed in a coaxial cable?
The electric field in a coaxial cable is typically strongest at the inner conductor and decreases as you move towards the outer conductor. This is because the inner conductor carries a higher potential difference compared to the outer conductor. The electric field is also more concentrated near the edges of the conductors.
3. How does the electric field affect signal transmission in a coaxial cable?
The electric field in a coaxial cable plays a crucial role in signal transmission. It allows for the propagation of electric signals along the length of the cable, and it also helps to maintain the integrity of the signal by preventing interference from external electric fields.
4. What factors can affect the strength of the electric field in a coaxial cable?
The strength of the electric field in a coaxial cable can be affected by several factors, including the distance between the inner and outer conductors, the material and thickness of the insulating layer between the conductors, and the voltage and current being transmitted through the cable.
5. How is the electric field in a coaxial cable calculated?
The electric field in a coaxial cable can be calculated using the formula E = V/d, where E is the electric field strength, V is the voltage difference between the inner and outer conductors, and d is the distance between the conductors. This formula assumes a perfectly cylindrical cable with a uniform electric field distribution.
