Electric Field Inside a Gaussian Surface with Point Charge q
The discussion centers on the application of Gauss's law regarding the electric field inside a Gaussian surface with a point charge located outside. It emphasizes that while the electric flux is zero if no net charge is enclosed, this does not imply that the electric field inside the surface is also zero unless there is symmetry in the configuration. The lack of symmetry in the scenario described prevents the conclusion that the electric field must be zero, as the mathematical implications of Gauss's law do not hold without symmetry. The conversation highlights a common misunderstanding among students regarding the relationship between electric flux and electric field strength. Understanding the necessity of symmetry in applying Gauss's law is crucial for accurate interpretations in electrostatics.
Jaccobtw
Gauss's Law States that if there is no charge enclosed by a gaussian surface, then the electric field must be zero. But how is this the case?
E = q/A##\epsilon_o##
If I have a point charge q right outside of a gaussian surface, it makes sense that the flux is zero inside the surface because the electric field going in equals the electric field going out. However, how would the electric field be zero inside? Wouldn't it just take on the electric field of that area in space relative to the point charge q?
Gauss's law states that if there is no net charge enclosed by a gaussian surface then the electric flux is zero (and not that the electric field is zero).
If there is no net charge inside, and hence the flux is zero, then we can deduce that the e-field is zero ONLY IF there is some additional symmetry argument. The situation you describe with the charge outside a gaussian surface is not symmetrical, hence mathematically what happens is that from $$\oint \vec{E}\cdot d\vec{S}=0$$ we can NOT deduce that $$\vec{E}=0$$ because there is no symmetry that would allow us to get the ##\vec{E}## outside of the flux integral, so the following implication $$\oint \vec{E}\cdot d\vec{S}=0\Rightarrow \vec{E}\cdot\oint d\vec{S}=0\Rightarrow \vec{E}=0$$ simply is NOT valid mathematically.
Likes Orodruin and Jaccobtw
If there is no net charge inside, and hence the flux is zero, then we can deduce that the e-field is zero ONLY IF there is some additional symmetry argument. The situation you describe with the charge outside a gaussian surface is not symmetrical, hence mathematically what happens is that from $$\iint \vec{E}\cdot d\vec{S}=0$$ we can NOT deduce that $$\vec{E}=0$$ because there is no symmetry that would allow us to get the ##\vec{E}## outside of the flux integral, so the following implication $$\iint \vec{E}\cdot d\vec{S}=0\Rightarrow \vec{E}\cdot\iint d\vec{S}=0\Rightarrow \vec{E}=0$$ simply is NOT valid mathematically.
Why did you use double integrals?
Well, the flux integral is a surface integral and so its usually a double integral, but you maybe right, I should have used the $$\oint$$ which means surface integral over a closed surface. I will edit my post shortly.
That is not the main point of this btw, the main point is that there is no symmetry in the situation you describe.
This point is way too little emphazised in most treatments and a very common source of misunderstanding among students. The usual takeaway from the typical example of a spherical symmetry is ”oh, EA = enclosed charge/epsilon, very convenient” and the symmetry argument preceeding the statement is often forgotten. It needs to be hammered in.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
