Electric field inside a polarized dielectric sphere
In summary, the conversation discusses Gauss' law in dielectric and how it can be used to find the electric field in a dielectric sphere with no free charge. The solutions for the electric field, using both ##E = \frac {-kr^2 \hat r} {ε_0}## and ##E = \frac {-P} {3ε_0}##, are not the same due to the fact that the polarization is a function of ##r## and points outward, rather than in a single direction. It is important to use the full form of Gauss' law and consider both the particular and homogeneous solutions to get a complete solution for the electric field.
Saptarshi Sarkar
99
A dielectric sphere of radius R carries a polarization ##P = kr^2\hat r## where k is a constant and r is the distance from the origin. Then the electric field inside the sphere is?
##ρ_b = -\nabla .P##
My attempt:
I know from Gauss' law in dielectric
##\nabla .D = ρ_f##
where ##D = ε_0E + P##,
so as
##ρ_f = 0## (as there is no free charge in the sphere)
=> ##\nabla .D = 0##
=> ##ε_0\nabla .E = \nabla .P##
from this I get
But, I know that for a uniformly polarization dielectric sphere, ##E = \frac {-P} {3ε_0}##
Why are both the solutions not the same?
Likes curious_mind
This one is not uniformly polarized. The polarization is a function of ## r ##, and it points radially outward, instead of in a single direction. ## \\ ## In any case, don't jump to conclusions that since ## \nabla \cdot E=C \nabla \cdot P ##, that ## E=C P ##. This often is not the case with these problems. In this case you might be right, but a homogeneous solution to ## \nabla \cdot E=0 ## sometimes needs to get added to the solution ## E=CP ## for cases like this. Suggest you use Gauss' law and find the enclosed ## \rho_p ## to check your answer.
Likes Saptarshi Sarkar
This comes up a lot in both electrostatic and magnetostatic problems: ## \\ ##
Foe electrostatics, we have ## D=\epsilon_o E+P ##. We have ## \nabla \cdot D=\rho_{free} ##. In cases where ## \rho_{free}=0 ##, we have ## \nabla \cdot D=0 ##. Even though we then have ## \epsilon_o \nabla \cdot E=-\nabla \cdot P ##, most often it is not the case that ## \epsilon_o E=-P ##. ## \\ ## A similar thing can be said for magnetostatics, where ## B=\mu_o H+M ##, and ## \nabla \cdot B=0 ##. Most often, it is not the case that ## \mu_o H=-M ##, even though ## \mu_o \nabla \cdot H=-\nabla \cdot M ##. ## \\ ## We have a particular solution to the differential equation, but we often need to add a solution to the homogeneous equation, ## \nabla \cdot E=0 ##, or ## \nabla \cdot H=0 ##, to get the complete solution for ## E ## or ## H ##.
Related to Electric field inside a polarized dielectric sphere
What is an electric field inside a polarized dielectric sphere?
The electric field inside a polarized dielectric sphere refers to the strength and direction of the electric field at different points within the sphere. It is affected by the polarization of the material and the external electric field applied to the sphere.
How is the electric field inside a polarized dielectric sphere calculated?
The electric field inside a polarized dielectric sphere can be calculated using the equation: E = E0 + P/ε0, where E0 is the external electric field, P is the polarization vector, and ε0 is the permittivity of free space.
What is the relationship between the electric field and polarization inside a dielectric sphere?
The electric field and polarization inside a dielectric sphere are directly proportional to each other. As the polarization increases, the electric field also increases in the same direction.
How does the electric field inside a polarized dielectric sphere differ from that of a non-polarized sphere?
The electric field inside a polarized dielectric sphere is stronger and more complex compared to that of a non-polarized sphere. This is because the polarization creates an additional electric field inside the sphere, in addition to the external field.
What are some applications of understanding the electric field inside a polarized dielectric sphere?
Understanding the electric field inside a polarized dielectric sphere is important in various fields such as electronic devices, materials science, and medical imaging. It allows us to design and optimize devices that use dielectric materials, and also helps in understanding the behavior of dielectric materials in different environments.
