Electric Field inside a Sphere (Gauss' Law)
In summary, the problem involves a solid sphere with outer radius 15 and inner radius 5, containing a total charge of 20 C between r=5 and 15. The electric field at r = 8 is then calculated using Gauss' Law and the volume and charge density of the solid part of the sphere. The distribution of the charge inside the Gaussian sphere does not affect the calculation.
jumbogala
423
A sphere has outer radius 15 and inner radius 5.
Between r= 5 and 15, the sphere is solid and contains a total charge of 20 C.
At r < 5, the sphere is hollow.
Calculate the electric field at r = 8.
Gauss' Law --> EA = (q)/epsilon zero
What I'm confused about is the hollow sphere part. But ignoring that, here's how I would do the problem.
The volume of the entire sphere is (4/3)pi(15^3) = 14137.16694 m^3.
The volume of the hollow part is (4/3)pi(5^3)= 523.598 m^3.
Therefore, the volume of just the solid part is 14137 - 523 = 13613.568 m^3.
The charge density per volume is then 20 / 13613 = 0.001469.
To calculate the electric field at r = 8, I need to find the volume of such a sphere.
Same procedure as above, take the volume minus the empty part to find 1621.06.
Multiply this by the charge density... 1621.06 * 0.001469 to find 2.38133 C.
This is the internal charge.
Take a gaussian surface of radius 8. It will have surface area (4pi)(8^2)
E = (internal charge)/ (epsilon zero)(area)
E= 2.38 / (eps. zero)(804.24) = huge number, 3.34 x 10 ^ 8.
What's confusing me is whether it's ok to take the surface area of a sphere with radius 8, because of that hollow part. Do I need to subtract the hollow part's surface area or something?
With the Gaussian surface you are determining the charge inside. The surface of course is the spherical surface at 8. No other surface need apply.
As to the rest of it, that looks OK. Subtract out the hollow volume to determine charge density and then determine the volume at 8 subtracting out the void again.
So it doesn't really matter how the charge is distributed inside the Gaussian sphere, then? The charge can be all on the surface or all at the center, etc. and the procedure is still the same?
Related to Electric Field inside a Sphere (Gauss' Law)
1. What is Gauss' Law and how does it relate to electric fields inside a sphere?
Gauss' Law is a fundamental law of physics that relates the electric flux through a closed surface to the total charge enclosed within that surface. In the case of a sphere, this law states that the electric field inside the sphere is directly proportional to the total charge enclosed by the sphere.
2. How is the electric field inside a sphere calculated using Gauss' Law?
To calculate the electric field inside a sphere using Gauss' Law, we first need to determine the total charge enclosed by the sphere. This can be done by finding the sum of all the charges inside the sphere or by using the charge density and the volume of the sphere. Once the total charge is known, we can use the formula E = Q/(4πε0r^2), where E is the electric field, Q is the total charge, ε0 is the permittivity of free space, and r is the distance from the center of the sphere.
3. How does the electric field inside a conducting sphere differ from that of a non-conducting sphere?
In a conducting sphere, the electric field inside the sphere is zero. This is because in a conductor, charges are free to move and will redistribute themselves in such a way that the electric field inside the sphere is cancelled out. In a non-conducting sphere, the electric field inside the sphere is non-zero and is determined by Gauss' Law.
4. Can the electric field inside a sphere be uniform?
Yes, the electric field inside a sphere can be uniform if the charge distribution inside the sphere is also uniform. In this case, the electric field will have the same magnitude and direction at all points inside the sphere.
5. How does the electric field inside a sphere change as the distance from the center of the sphere increases?
The electric field inside a sphere decreases as the distance from the center of the sphere increases. This is because the electric field is inversely proportional to the square of the distance from the center, as shown in the formula E = Q/(4πε0r^2). As the distance increases, the denominator of this formula increases, resulting in a smaller electric field.
