Electric field inside conductor
In summary, an external electric field is applied across a metal with a void inside it. The electric field "inside" the metal becomes zero due to the movement of electrons.
jd12345
256
electric field "inside" conductor
Well consider a conductor with a void inside it. An external constant electric field is applied across it.
I would like to distinguish between two things : when i say "inside" the conductor i mean the void, the empty space which contains nothing but air and
when i say "in" the conductor i mean the the metal which has loads of free electrons inside it
So i fully understand why the electric field "in" the conductor becomes zero. Th electrons will rearrange themselves to cancel it . But why would the electric field "inside" the conductor become zero. IT has no free electrons and the electric field would remain as it is in that free space. Only "in" the metal should the electric field become zero
When electric field is applied all the electrons "in" the metal would start to move and rearrange themselves until they feel no force so electric field "in" the metal becomes zero
But there are no free electrons "inside" the conductor - so electric field remains as it is there
I hopei'm clear
hi jd12345! :smile:
jd12345 said:
… But why would the electric field "inside" the conductor become zero. IT has no free electrons and the electric field would remain as it is in that free space. Only "in" the metal should the electric field become zero
you mean that if there was free space with a non-zero electric field,
and you put this conductor into that space, then by the principle of superposition, why isn't the field inside the conductor the same non-zero field as before?
because the non-zero field in the free space affects the charge distribution (the electrons) on the outside surface of the conductor, so when you "superpose", you're not "superposing" the same field of the conductor as in the zero-field case :wink:
jd12345 said:
I hopei'm clear
You are very clear as this is a common question. There are mathematical explanations to this question. One is based on the Laplace equation for the electric potential within the void with a constant potential on its boundary. since there is no free charge inside the void, the solution is a constnt potential all through the void and this means zero electric field.
I can't understand tiny-tim's answer, but it seems to be a mathematical explanation too.
However I think you are looking for a more physical explanation. Then this explanation may help:
Imagine two points on the boundary of the void. To move a charge from one point to the other "through the conductor", zero work is requited because they have the same potential. Now you can chose any path between the two points "through the void". Again zero work is required. This means the the work done on the charge by the field is zero. This in turn means the field ( which applies the force) is zero OR its component along the path changes direction so that the net work done by the field along the path is zero. I think its easy to prove that the latter is possible only when there is free charge in the void ( I have no solid proof now).
Likes arestes
self delete
I can explain this phenomenon using the principles of electrostatics. Inside a conductor, the electric field is zero because the free electrons within the conductor are able to move freely and distribute themselves in such a way that the net electric field inside the conductor is canceled out. This is known as electrostatic shielding.
In the case of an empty space or void inside the conductor, there are no free electrons present to cancel out the electric field. Therefore, the electric field remains constant and is not affected by the presence of the conductor.
It is important to note that the electric field inside a conductor is not completely zero, as there may be some residual electric field due to imperfections or surface charges on the conductor. However, this electric field is very small and can be neglected in most cases.
In summary, the electric field inside a conductor is zero due to the presence of free electrons that can redistribute themselves and cancel out the external electric field. This phenomenon is crucial in understanding the behavior of electric fields and conductors.
FAQ: Electric field inside conductor
What is an electric field inside a conductor?
An electric field inside a conductor refers to the distribution of electric charges within the conductor. This field exists due to the movement of electrons within the conductor, creating a force that can push or pull other charges.
Is there an electric field inside a conductor?
Yes, there is an electric field inside a conductor. However, the electric field inside a conductor is zero in a state of equilibrium, meaning there is no net movement of charges within the conductor.
How is the electric field inside a conductor different from outside?
The electric field inside a conductor is different from outside because the conductor's surface allows free movement of charges, while the outer surface of the conductor repels electric charges.
Why does the electric field inside a conductor become zero in equilibrium?
The electric field inside a conductor becomes zero in equilibrium because the charges within the conductor rearrange themselves to cancel out any electric field that may exist. This ensures that there is no net movement of charges within the conductor.
Can the electric field inside a conductor be manipulated?
Yes, the electric field inside a conductor can be manipulated by applying an external electric field. This can cause the charges within the conductor to rearrange themselves, resulting in a non-zero electric field inside the conductor.
