Electric field inside hollow conductor boundary value problem
In summary, the conversation discusses the explanation given in Purcell's E&M book for why the field is zero inside a hollow conductor of any shape. The proof involves using Laplace's equation and the boundary condition of the region being an equipotential. The uniqueness theorem states that the potential inside the conductor is constant and equal to the potential on the surface. The individual in the conversation is confused about why the potential inside couldn't be constant but not equal to the potential on the surface. The response clarifies that this would result in a discontinuity and not satisfy Laplace's equation.
Tomkat
Hi,
I am in Purcell's E&M book at the section explaining why the field is zero inside a hollow conductor of any shape. The proof given is that the potential function inside the conductor must obey Laplace's equation, and that the boundary of the region (in this case a rectangular metal box) is an equipotential. It calls the potential on the box some constant phi, then states that one solution (i.e. value of the potential inside the box) is that the potential is constant throughout the volume and equal to phi, the potential on the surface. Then it states by the uniqueness theorem that this is the only solution.
I understand all of this except why one couldn't say: one solution is that the potential is constant throughout the volume and *not equal to* phi (the potential on the surface of the box still being equal to phi of course). Therefore this is the only solution. The proof would come out the same, but it is this mathematical step that confuses me. Thanks,
Tomkat
\phi here is the boundary condition for the Laplace equation. If you define the interior to be some constant other than \phi, then there must be a discontinuity at the boundary. This would not satisfy Laplace's equation since we would have to take the derivative at the discontinuity causing the Laplacian to be nonzero.
Considering the laplace equation, We know the whole conductor is an equipotential, including the surface of it.
That makes some more sense. Thank you.
Hi Tomkat,
Thank you for your question. The proof for the electric field being zero inside a hollow conductor is based on the fact that the potential inside the conductor must obey Laplace's equation and that the boundary of the region is an equipotential.
In this case, the boundary value problem is set up in such a way that the potential on the surface of the conductor is held constant at a value of phi. This means that the potential inside the conductor can only take on values that are equal to phi, as any other value would not satisfy the boundary condition.
If we were to consider a solution where the potential inside the conductor is constant but not equal to phi, this would not satisfy the boundary condition and therefore would not be a valid solution. The uniqueness theorem states that there can only be one solution that satisfies the given boundary conditions, and in this case, that solution is a constant potential equal to phi throughout the volume of the conductor.
I hope this helps clarify the mathematical step that was confusing to you. If you have any further questions, please don't hesitate to ask.
Best,
FAQ: Electric field inside hollow conductor boundary value problem
1. What is the purpose of solving the electric field inside a hollow conductor boundary value problem?
The purpose of solving this problem is to determine the distribution of electric field inside a hollow conductor, which can provide valuable information about the behavior of electric charges and currents in the conductor.
2. How is the electric field inside a hollow conductor related to the boundary conditions?
The electric field inside a hollow conductor is related to the boundary conditions through Gauss's Law, which states that the net electric flux through a closed surface is equal to the enclosed charge divided by the permittivity of the medium. This allows us to determine the electric field at any point inside the conductor based on the charges and boundary conditions present.
3. What are the boundary conditions that must be considered in this problem?
The boundary conditions in this problem include the shape and size of the conductor, the distribution of charges on the surface, and the surrounding environment, such as the presence of other conductors or dielectric materials. These conditions determine the behavior of the electric field inside the conductor.
4. How is the electric field affected by the geometry of the hollow conductor?
The electric field inside a hollow conductor is affected by the geometry of the conductor, specifically the ratio of its inner and outer radii. This determines the distribution of charges on the surface and the resulting electric field inside the conductor.
5. What are some real-world applications of solving the electric field inside a hollow conductor boundary value problem?
This problem has various applications in electrical engineering, such as designing and optimizing the performance of antennas, capacitors, and transmission lines. It is also relevant in the study of electromagnetic shielding and the behavior of electric fields in conductors used in electronic devices.
