Tiago3434
Figure 23-30 shows two nonconducting spherical shells fixed in place. Shell 1 has uniform surface charge density +6.0 µC/m2 on its outer surface and radius 3.0 cm. Shell 2 has uniform surface charge density -3.8 µC/m2 on its outer surface and radius 2.0 cm. The shell centers are separated by L = 14 cm. What are the magnitude and direction of the net electric field at x = 2.0 cm?
So this question is kinda two-fold:
First: my initial idea was that the field at x=2.0cm was just zero, since it was inside a uniformly charged sphere. I even thought about a gaussian surface inside shell 1, and because it didn't have any charges inside it, the electric field was zero. Upon seeing that the answer said that was wrong, I realized that the spheres are non conducting, so the field inside sphere 1 due to the charges of such sphere was going to be zero, but the field inside sphere 1 due to the charges of the sphere 2 was not null. Given that they are non conducting, then the charges on the surface wouldn't be able to reorganize themselves to nullify the field inside sphere 1. Is this explanation correct? It's just an idea for why my initial guess wasn't correct, and I don't know if it's true or not.
Second: why Gauss' law doesn't give the proper answer? Am I misapplying it?
