Electric Field & Motion: Understanding Why it Doesn't Change
In summary, the electric field of a charge can be found in its rest frame by using the electric field measured in that frame, and the gamma factor changes the value for the component electric field if it is perpendicular to the direction of the charge's motion. The electric field increases by superposition of "extra" electric fields, and is proportional to the charge density. The retarded potential approach can be used to find the electric field in any frame.
Clueless
I understand from my classes that, when looking to calculate the electric field of a charge we can use the electric field measured in its rest frame to find its electric field in the lab frame (where the charge is moving). The gamma factor changes the value for the component electric field if it is perpendicular to the direction of the charge's motion.
I don't understand why it is not also for the parallel part: if length contraction and charge conservation are at play, then in the lab's frame, there would be "more" charges per metre along the axis where the charges is moving?
And so the electric field increases by superposition of "extra" electric fields? And how does is discriminate between the direction of motion and the direction perpendicular?
Thanks for reading!
You cannot just look at the electric field and make conclusions based on that. The full electromagnetic field behaves as a rank two antisymmetric tensor under Lorentz transformations and its source is a 4-vector and not a scalar. In order to properly understand how it transforms, you must take these things into account.
Likes Clueless
I see. Thanks for pointing me in the right direction to understanding this!
In the first paragraph you look at a single charged particle, but then in the second paragraph you switch to a collection of charged particles.
It depends on the charge distribution. If you are modelling a long straight wire you have an essentially infinite number of charged particles moving in the direction of motion, not so in the transverse direction..
http://web.mit.edu/sahughes/www/8.022/lec12.pdf has the argument I usually see, but it's not as detailed as I'd like. I suspect a missing piece of the argument was covered in a previous section.
The first idea is that you can find out how the electric field transforms by considering a parallel plate capacitor in motion - i.e. figuring out how the electric field in this example shows you how it transforms in general.
The second idea is that you use Gauss's law, and find that the integral of the electric field normal to a boundary is equal to the enclosed charge. Making the boundary in question a cube around one of the plates, and knowing that the electric field is nonzero only between the plates and is perpendicular to the plates (ignoring edge effects) then gives you the needed diagram. For a parallel plate capacitor, this analysis gives you that the electric field is proportional to the charge density.
The third idea is that the charge density doesn't change when you boost the capacitor in the direction normal to the plates. Then, since the charge density doesn't change, the electric field doesn't change either.
An alternative idea that may be more advanced is to use the idea of the retarded potential to compute the electric field in a moving frame (such as Jeffminko's equations, https://en.wikipedia.org/w/index.php?title=Jefimenko's_equations&oldid=695260811). But I usually see the parallel plate capacitor approach in introductory E&M texts.
The advantage of the retarded potential approach (Jeffminko's equations) is that (carried out properly) it demonstrates that you CAN find the electric field in any frame knowing only the electric and magnetic field in one frame. This is not particularly obvious, but is vital to the tensor approach. It shows that you only need to solve the problem once in any frame you like, and gives you a recipie to transform this solution to any other frame you desire.
Related to Electric Field & Motion: Understanding Why it Doesn't Change
1. What is an electric field?
An electric field is a region around a charged particle or object in which another charged particle experiences a force.
2. How is the strength of an electric field measured?
The strength of an electric field is measured in units of volts per meter (V/m). This represents the amount of force per unit charge that a charged particle would experience at a specific point in the field.
3. What causes an electric field to exist?
An electric field is created by the presence of a charged particle or object. The charged particle or object creates a force that extends outward into the surrounding space, forming the electric field.
4. Why doesn't the electric field change?
The electric field is based on the presence and properties of charged particles or objects. As long as these particles or objects remain in the same position and maintain their charge, the electric field they create will remain constant.
5. How does motion affect an electric field?
Motion does not directly affect the strength or existence of an electric field. However, the movement of charged particles or objects can cause changes in the electric field, such as creating a magnetic field or changing the direction of the electric field lines.
  • Other Physics Topics
