Electric Field of a circular arc at a point
In summary, the conversation discusses finding the electric field at the origin due to a uniformly charged circular arc wire with radius 'r' and linear charge density λ. The solution method involves using symmetry to determine the y component of the electric field and using dq = λds instead of dy = Rdθ to integrate and arrive at the correct answer.
Hijaz Aslam
66
Given that the circular arc wire with radius 'r' has a linear charge density ##\lambda##. What is the Electric field at the origin?
##\vec{E}=\frac{kq}{r^2}## where ##k=9\times10^9## is a constant.
3. The Attempt at a Solution
I took a small segment dy ##\theta## above the x-axis with charge ##dq=\lambda dy##. Therefore ##d\vec{E}=\frac{k\lambda cos\theta dy}{r^2}## as all other charges along the y-axis cancel out each other.
Now ##cos\theta=\frac{x}{r}##. And ##x^2+y^2=r^2## is the equation of the arc.
Therefore ##cos\theta=\frac{\sqrt{r^2-y^2}}{r}##. And then proceeding to integrate ##d\vec{E}=\frac{k\lambda \sqrt{r^2-y^2} dy}{r^3}## and arrive at an answer.
But my text tackles the question the same way until, at a point it takes ##dy=rd\theta## and then substitutes and integrates ##d\vec{E}=\frac{k\lambda cos\theta d\theta}{r}## and arriving at an answer. But my answer differs from the one arrived by my textbook. Am I wrong somewhere?
##dq=\lambda dy## would mean every "step" dy gives the same charge, and equivalently the same length of the wire. This is not true.
mfb : That is the condition given in the question. Moreover my text starts the solution in the same way. (The wire is uniformly charged)
Use symmetry to conclude what about the y component of E at the origin?
For the x component, dEx = k cosθ dq/R2 should be apparent.
What is dq in terms of arc length ds?
Go that way & you will wind up agreeing with your textbook.
As mfb implied, dy = R dθ is incorrect. R dθ is an element of arc length ds, not an element of distance along the y axis.
Your approach seems correct, but it's possible that there may be a mistake in your integration or substitution. It's always a good idea to double check your work and make sure all the steps are correct. Additionally, it's helpful to compare your answer to the one given in the textbook to see where the discrepancy may be coming from. If you're still unsure, you can always ask a classmate or your teacher for help.
Related to Electric Field of a circular arc at a point
1. What is the electric field of a circular arc at a point?
The electric field of a circular arc at a point is a measure of the strength and direction of the electric force experienced by a charged particle at that point due to the presence of a circular arc with a certain charge distribution.
2. How is the electric field of a circular arc at a point calculated?
The electric field of a circular arc at a point can be calculated using Coulomb's Law, which states that the electric field at a point is directly proportional to the magnitude of the charge and inversely proportional to the square of the distance from the point to the charge.
3. What factors affect the electric field of a circular arc at a point?
The electric field of a circular arc at a point is affected by the magnitude and distribution of the charge on the arc, as well as the distance between the point and the arc. The shape and size of the arc also play a role in determining the electric field.
4. How does the direction of the electric field of a circular arc at a point affect charged particles?
The direction of the electric field of a circular arc at a point determines the direction of the electric force that will be exerted on a charged particle placed at that point. This force may cause the particle to move in a certain direction or experience a change in its velocity.
5. Can the electric field of a circular arc at a point be negative?
Yes, the electric field of a circular arc at a point can be negative. This indicates that the electric force exerted on a charged particle at that point will be in the opposite direction of the electric field vector. Negative electric fields may also indicate a repulsive force between two charged particles.
