Electric Field of a Toroid carrying a changing current I = kt on axis
  • Thread starter Thread starter PhDeezNutz
    Electric Toroid
The discussion revolves around calculating the electric field of a toroid with a time-varying current using the relevant equations derived from the Helmholtz Theorem. The initial calculations led to a curl of zero, which caused confusion regarding the validity of the derived electric field expression. A participant suggested an alternative approach using a formula from Griffiths, which yielded the correct answer through simplifying assumptions. The conversation highlights the importance of understanding the Helmholtz Theorem in electromagnetic theory. Ultimately, the participant expressed a desire to become more familiar with the theorem while confirming the validity of their solution.
PhDeezNutz
A toroidal coil has a rectangular cross section, with inner radius ##a##, outer radius ##a+w##, and height ##h##. It carries a total of ##N## tightly wound turns, and the current is increasing at a constant rate (##\frac{dI}{dt} = kt##). If ##w## and ##h## are both much less than ##a##, find the electric field at point ##z## above the center of the toroidal. [Hint: Exploit the analogy between Faraday fields and magnetostatic fields, and refer to Example 5.6 (In Griffiths)]
##B_{text{toroidal coil}} = \frac{\mu_0 NI}{2 \pi s} \hat{\phi}## where ##s## is the distance from the center of the toroidal coil (the origin if you will) (also ##\hat{\phi}## because I assumed the toroidal coil lies in the ##xy-\text{plane}##.
Since ##\nabla \times \vec{E} = - \frac{\partial \vec{B}}{\partial t}## which I believe implies that
##\vec{E} \left( \vec{r} \right) = \frac{1}{4 \pi} \int {\nabla’ \times \frac{\partial \vec{B}}{\partial t}}{\left| \vec{r} - \vec{r}’ \right|}\, d \tau’##
The relevant equation listed above as
##\vec{E} \left( \vec{r} \right) = \frac{1}{4 \pi} \int {\nabla’ \times \frac{\partial \vec{B}}{\partial t}}\frac{1}{\left| \vec{r} - \vec{r}’ \right|}\, d \tau’##
Seems to me to be a natural consequence of the Helmholtz Theorem so I don’t see why it wouldn’t be valid but strangely I’m finding a curl of ##0##. Here’s the calculation.
If ##\frac{\partial I}{\partial t} = k \Rightarrow I = kt##. Plugging ##I## into ##\vec{B}## we get
##\vec{B} = \frac{\mu_0 N kt}{2 \pi s’} \hat{\phi}’##
And taking the partial derivative wrt ##t##
##\frac{ \partial \vec{B}}{\partial t} = \frac{\mu_0 N k}{2 \pi s’} \hat{\phi}’##
In cylindrical coordinates the primed curl of the above is
##\nabla’ \times \frac{ \partial \vec{B}}{\partial t} = \nabla’ \times \frac{\mu_0 N k}{2 \pi s’} \hat{\phi’} = \frac{1}{s’} \left(\frac{\partial}{\partial s’} \left(s’ \frac{ \partial \vec{B}}{\partial t} \right) \right) \hat{\phi}’##
## = \frac{1}{s’} \left(\frac{\partial}{\partial s’} \left(s’ \frac{\mu_0 N k}{2 \pi s’} \right) \right) \hat{\phi}’ = 0 \hat{\phi’}##
Which makes the following integral zero
##\vec{E} \left( \vec{r} \right) = \frac{1}{4 \pi} \int {\nabla’ \times \frac{\partial \vec{B}}{\partial t}}\frac{1}{\left| \vec{r} - \vec{r}’ \right|}\, d \tau’ = 0##
Where did I go wrong with the curl calculation because the answer is definitely not zero?
Thanks for any help in advanced.
Edit all instances of the integral should be
##\vec{E} \left( \vec{r} \right) = \frac{1}{4 \pi} \int \frac{\nabla’ \times \frac{\partial \vec{B}}{\partial t}}{\left| \vec{r} - \vec{r}’\right|} \, d \tau’##
This doesn't look correct to me.
I believe the Helmholtz theorem leads to $$\vec{E} \left( \vec{r} \right) = -\frac{1}{4 \pi} \nabla \times \int \frac{\frac{\partial \vec B(\vec r \, ', t)}{\partial t}}{\left| \vec{r} - \vec{r}\,’\right|} \, d \tau’.$$ I don't see how to get from this to your expression.
Thankyou @TSny
I figured it out.
Instead of fussing with the Helmholtz Theorem and its intricacies I just appealed to a formula in Griffiths
##\vec{E} \left(\vec{r}\right) = - \frac{1}{4 \pi} \int \frac{\frac{\partial \vec{B}}{\partial t} \times \vec{R}}{R^3} \, d \tau'##
I made some simplifying assumptions along the way and got the same answer the solution manual got via a slightly different method.
That said the simplifying assumptions regarding smallness parameters were probably favorably made in light of knowing the final answer :D
That said the Helmholtz Theorem is something I should definitely get more familiar with.
Edit: just to be sure I only looked at the final solution. Not the workings. I believe my solution is valid due to the corroboration.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
