Electric field of charged particles problem
In summary, the electric force on a -3.00 µC charge placed on the y-axis at y = 0.900 m will be 0.1796 N.
kevinf
90
Two 9.00 µC charged particles are located on the x axis. One is at x = 1.00 m, and the other is at x = -1.00 m.
(a) Determine the electric field on the y-axis at y = 0.900 m.
(b) Calculate the electric force on a -3.00 µC charge placed on the y-axis at y = 0.900 m
the professor didn't really go over this type of question yet but i would like to get ahead and finish it. i know to apply the electric field equation (K)(q)/r^2 but i am not very good with working with components. can somebody explain this to me? thanks
The magnitude of the fields due to two charges will be same. But one field will go away from the charge and another towards the charge. Take vertical and horizontal components of the fields.
Vertical component = Esin(theta) and horizontal component = Ecos(theta) Find the resultant field.
i am not sure what you mean by one field will go away one will go towards the charge
One is repulsive and the other is attractive. Draw the diagram and see.
but i thought both charges are positive
Sorry. I didn't notice that. In that case both will be repulsive.
Vertical components will add up.And the horizontal components will cancel each other.
i did what you said but kept getting it wrong. wouldn't i use tangent first to find the bottom angles of the triangle that it would form and then use pythagorean theorem to find out what the length of the sides of the triangle are? i think the horizontal component should be 0. but i am having trouble with the vertical component of the problem. so i would do (9)*(Ke)/(1.81) and then multiply that by sin(angle that i calculated earlier) right? i am not getting the right answer.
I am getting 0.1796N.
If this is correct, show the details of your calculations.
FAQ: Electric field of charged particles problem
What is an electric field?
An electric field is a region in space where electrically charged particles experience a force. It is created by the presence of charged particles and can be visualized as lines of force extending from positive charges to negative charges.
How is the strength of an electric field measured?
The strength of an electric field is measured in units of voltage per distance, also known as volts per meter (V/m). This value represents the force experienced by a unit charge in the presence of the electric field.
How do charged particles interact with an electric field?
Charged particles, such as electrons and protons, will experience a force when placed in an electric field. This force can either attract or repel the particles, depending on their respective charges.
How does the distance between charged particles affect the electric field?
The strength of an electric field is inversely proportional to the square of the distance between charged particles. This means that as the distance between particles increases, the electric field weakens.
How can I calculate the electric field of charged particles?
The electric field can be calculated using the formula E = kQ/r^2, where E is the electric field strength, k is the Coulomb's constant, Q is the magnitude of the charge, and r is the distance between the charged particles. This formula applies to point charges, while for more complex systems, the electric field can be calculated by summing the contributions from individual charges.
