Electric field of concentric conducting spheres
In summary, the problem involves a conducting sphere inside a conducting shell with charges q1 and q2 on the sphere and shell, respectively. The electric field at a point P inside the shell is being calculated using Gauss's Law and a Gaussian surface. Since the electric field at all points on the Gaussian surface is zero, the net charge enclosed within the surface must also be zero. This means that there is a charge of -q1 on the inner surface of the shell to cancel out the +q1 charge on the solid sphere. The net charge on the shell is +q2, making the net charge on the outer surface of the shell equal to +q2 + q1.
emr564
Why is the Qenclosed zero if there's a charge inside the shell?
A solid conducting sphere of radius a is placed inside a conducting shell which has an inner radius b and an outer radius c. There is a charge q1 on the sphere and a charge q2 on the shell.
Find the electric field at point P, where the distance from the center O to P is d, such that b<d<c.
There's a diagram which shows:
radius of solid conducting sphere = a
inner radius of conducting shell = b
outer radius of conducting shell = c
O is the center from which all radii are measured.
Flux = EA = Qencl/εnaught
A = 4∏r^2
E = Qenclosed/ (εnaught*4∏d^2)
I have the solution already, which is E=0, but I don't understand why the charge enclosed is 0. I understand that the charge on the shell spreads to the outer surface of that shell since it's a conductor, so that charge wouldn't be enclosed in the Gaussian sphere with radius d. I don't get why the charge on the solid sphere doesn't count, though.
In the problem before it, the question asked for the electric field at a point in between the solid sphere and the spherical shell, and the answer was kq1/d^2, which means that in the space between, the enclosed charge is q1.
The electric field in the conducting material of the shell itself is zero. That's a property of a conductor.
Use a spherical surface (for a sphere centered at O, having a radius between b and c) as your Gaussian surface. The E-field at all points on the Gaussian surface is zero. (The Gaussian surface lies entirely within conducting material.) Therefore, Gauss's Law tells us that the net charge enclosed within this sphere is zero.
There is a charge of q1 on the center sphere. The only other place (inside of our Gaussian surface) where charge can reside is on the inner surface of the spherical shell. Therefore, the charge on the inner surface of the shell (r = b) is -q1, making the charge enclosed equal to zero.
What is the net charge on the exterior surface of the shell?
Likes gracy
Thanks. I understood that the field at points on the Gaussian surface is zero, but I don't understand where the -q1 comes from. The net charge on the exterior surface of the shell is +q2, and the net charge on the solid sphere is +q1. But why is it that at a point A between the inner shell surface and the outer solid sphere surface, the charge enclosed is +q1 (the charge on the solid sphere), but at a point P inside the shell (between outer and inner surfaces), all the sudden the charge enclosed is zero? Is it something like the +q1 from the solid sphere induces a charge of -q1 on the inner surface of the shell?
The net charge on the shell (the sum of the charges on both inner & outer surfaces) is +q2. But, since the net charge enclosed in our Gaussian surface is zero, there is a charge of -q1 on the inner surface -- to cancel the +q1 charge on the central sphere.
The net charge on the shell is given by:
[itex]q_{\text{Shell}}=q_\text{inner} + q_\text{outer}[/itex]
[itex]+q_2= -q_1+ q_\text{outer}[/itex]​
Therefore,
[itex]+q_2 +\, +q_1 =q_\text{outer}[/itex]​
Likes gracy
Okay, thank you for helping. I just realized the gap in my logic which would be too confusing to explain...
Related to Electric field of concentric conducting spheres
What is the equation for the electric field of concentric conducting spheres?
The electric field of concentric conducting spheres is given by the equation E = k(Q/R^3) where k is the Coulomb's constant, Q is the charge of the inner sphere, and R is the distance from the center of the spheres.
How does the electric field change as the distance from the center of the spheres increases?
The electric field decreases as the distance from the center of the spheres increases. This is because the electric field follows an inverse square law, meaning that it decreases with the square of the distance.
Can the electric field of concentric conducting spheres be negative?
Yes, the electric field can be negative if the charges on the inner and outer spheres have opposite signs. In this case, the electric field points towards the center of the spheres.
What is the significance of having concentric conducting spheres?
Concentric conducting spheres allow for the creation of a uniform electric field between the spheres. This can be useful in experiments or applications that require a precise and controlled electric field.
How does the electric field of concentric conducting spheres compare to that of a point charge?
The electric field of concentric conducting spheres is similar to that of a point charge at a large distance from the spheres. However, as the distance from the spheres decreases, the electric field becomes more complex and is influenced by the charges on both spheres.
