Decimal
- 75
- 7
Hello,
I think I solved the question, but I am confused by the elaboration on the exercise given by my professor.
1. Homework Statement
A very large plate charged with charge Q is placed between x = -d and x=0. A similar plate charged with charge 3*Q/2 is placed between x = 3*s and x = 3*s + d. Here, s and d are given constants.
Between the plates exists a spatial charge ρ, between x = 0 and x = 3s. Consider two points P and S placed on either side of the two plates on the x-axis, but also very close to them. Point P is placed at Xp > 3*s+d, and Point S at Xs < -d.
Calculate the electric field in point P and S. The plates are large enough that side effects can be ignored and the electric field will only have a component parallel to the x-axis.
[/B]
Gauss law for electric fields
[/B]
This is what I did:
Because these plates are very large, the electric field is not dependent on distance from the plates and the electric field will be the same size on either side, just in the opposite direction.
Take a gauss cylinder through the plates with the two sides through point S and P.
∫Ep⋅dA + ∫Es⋅dA = Qenc/ε0
Then since Ep and Es point in the same direction as dA in both cases you can write
∫Ep*dA + ∫Es*dA = Qenc/ε0
I will call the surface of the cylinders side A'
Ep*A' + Es*A'=Qenc/ε0
Now this is where my problem arises. I know how to calculate Qenc and work out this equation, but in the elaborations given by my professor the equation becomes:
Ep*A' - Es*A'=Qenc/ε0
I don't understand where this minus comes from. dA and Es should point in the same direction right?
[/B]
[/B]
This is what I did:
