B Electric field on the equatorial line of a dipole
  • B
  • Thread starter Thread starter DrBanana
    Vector calculus
The electric field on the line bisecting two equal and opposite charges is non-zero, while the potential along that line is zero. The relationship between electric field and potential is given by E = -dV/dr, but this only considers the radial component. A more comprehensive approach using vector calculus reveals that the electric field is a three-dimensional vector, requiring consideration of all components. The dipole potential in spherical coordinates is correctly expressed with V = (1/4πε₀)(p cos θ/r²), highlighting the importance of the correct power of r. In the equatorial plane, while the potential is zero, the derivative with respect to z remains non-zero, indicating a non-zero electric field.
DrBanana
##\vec{E}## on the line that perpendicularly bisects the segment that joins two equal and opposite charges is non-zero, as it should be. But the potential of any point along that line is zero. But we know know that ##E=-\frac{dV}{dr} ##, where V is approximately ##\frac{1}{4\pi \epsilon} \frac{pcos\theta}{r}## (if the charges are close together) where p is the magnitude of the dipole moment . If I differentiate that with respect to r and set ##\theta=\frac{\pi}{2}##, I still get E=0. What gives?
DrBanana said:
What gives?
Nothing gives. The electric field is a three dimensional vector. You only calculated its radial component in the equatorial plane.
Likes renormalize
That's wrong. It should be:$$\overrightarrow{E}=-\overrightarrow{\nabla}V=-\hat{r}\frac{\partial V}{\partial r}-\hat{\theta}\frac{1}{r}\frac{\partial V}{\partial\theta}-\hat{\phi}\frac{1}{r\sin\theta}\frac{\partial V}{\partial\phi}$$
Ok I think I understand what happened. My physics book doesn't touch on vector calculus and only mentions ##E=-\frac{dV}{dr}##, however most of the forces in the book only have radial components anyway so it didn't matter. But that broke down here.
The dipole potential in spherical coordinates is $$V=\frac{1}{4\pi \epsilon_0}\frac{p~\cos\!\theta}{r^2}.$$Note the correct power of ##r## in the denominator. Also note that with ##z=r\cos\!\theta##, you have $$V=\frac{1}{4\pi \epsilon_0}\frac{p~z}{r^3}.$$This last expression can be considered to be the dipole potential in cylindrical coordinates. In the equatorial plane (##z=0##) the potential vanishes but not its derivative with respect to ##z## which you can easily calculate.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
