Electric field outside a parallel plate capacitor
In summary: But the field strength times the distance has to equal the voltage difference, so if you reduce the distance the field strength increases just as the ramp must get steeper if you make it shorter.
PainterGuy
940
70
Hi!
Could you please help me with the queries below? Thanks a lot.
Question 1:
My question is about the field outside the plates of parallel plate capacitor. It is said that the field(s) between positively and negatively charged plates gets added up but the field(s) outside the plates gets canceled up. I don't understand how the external field(s) could get canceled up.
Please have a look on this Figure #1 below.
In the figure above plate 1 is positively charged and plate 2 was initially neutral. As plate 2 is exposed to the field of positively charged plate, the charge in it gets redistributed and one side of it becomes negatively charged and the other side becomes positively charged. We should note that number of 'positive' field lines emanating from the lower face of plate 2 is equal to the number of positive field lines entering upper face. Also, the both plates are electrically neutral between their upper and lower faces/boundaries. By the way, I believe that in a positively charged plate, plate 1, the charges would also redistribute in a way that the upper face would be less positively charged compared to the other one. I hope you agree with me up to this point.
Now please have a look on Figure #2 below. It shows how electric field of parallel plate capacitor is shown at many places though I don't agree that the field could get canceled outside.
In Figure #3 below I'm trying to show how in my opinion charges get redistributed once both positively and negatively charged plates are brought close together. I cannot understand how fields could get canceled toward the upper face of positively charged plate and toward the lower face of negatively charged plate. Where am I going wrong?
Question 2:
Electric for a parallel plate is given as shown below.
E=Q/(ε0A) where ε0 is vacuum permittivity and A is area of the plates
E=Vab/d where Vab is potential difference between the plates and 'd' is distance between them
I don't understand how reducing the distance between plates increases electric field. If the charge and area of plates don't change, 'd' shouldn't matter. It's not that reducing the 'd' would affect the charge, Q. Could you please guide me with this?
You could watch the video between 6:09 - 6:21. That section shows how 'd' affects electric field.
applet used in the video: https://phet.colorado.edu/en/simulation/capacitor-lab
Thank you!
Viewing at a charged capacitor from a certain distance, the capacitor as a whole turns out to be neutral. So, one experiences no electrical field owing to the capacitor.
Reducing the distance between the plates increases the electric field strength inside the capacitor when the external voltage source remains connected.
Likes PainterGuy
The electric field is the gradient of the voltage, analogous to the way that the slope of a ramp is the gradient of the height - if you have two ramps that are both one meter high, the shorter ramp will be steeper than the longer one.
With the capacitor, the voltage difference between the two plates doesn't change as you change the distance (it can't - both plates are still connected to the vltage source). But the field strength times the distance has to equal the voltage difference, so if you reduce the distance the field strength increases just as the ramp must get steeper if you make it shorter.
Likes PainterGuy
Thank you, @Lord Jestocost, @Nugatory!
Yes, you are right that when a capacitor is looked at from a distance, it turns out to be neutral system. But my main question was more about when the capacitor is looked at from a closer distance. In other words, what figure between the two, Figure 2 and Figure 3, do you find correct? Many places I have been to online, use Figure 2. But I don't really understand how Figure 2 could be explained. In my opinion, Figure 3 correctly explains the electric field around the plates. By the way, while writing this post I checked a physics book by Young & Freedman and it uses a figure which looks more like Figure 3. Please have a look here: https://imageshack.com/a/img922/9967/VNJQP8.jpg
I understand what you are saying but I fail to understand how distance is important and why decreasing the distance would increase the electric field. In my opinion, electric field should only depend upon charge, Q, assuming area, A, is constant. Informally speaking, suppose there were 10 electric field lines when 'd' was 1 mm, then how making 'd' 0.5 mm would double the electric field lines?
Thanks for your help!
"Field lines" are not an effective way of thinking about this stuff quantitatively. They provide a kinda-OK handwavy intuition in some problems, but the parallel plate capacitor is not one of them.
The magnitude of the electrical field at a point is a measure of how much the voltage changes over distance, just as the steepness of a ramp is a measure of how much the height changes over horizontal distance.
If the voltage difference between the plates is 10 volts and the plates are 10 mm apart, then the voltage must change by 1 volt per mm as you move from one plate to the other. If the plates are 1 mm apart, then the voltage must change by 10 volts per mm to get a full 10 volts of change between the two plates.
Another way of thinking about it: imagine a test particle with positive charge ##Q## at the bottom plate. How much work would you have to do on it to move it to the top plate? ##Q\Delta{V}##, right? That's independent of the distance, as you're expecting. But that amount of work must also be equal to ##W=Fd## so the force you're acting against is dependent on the distance. But we also know that the electric field strength is proportional to the force by ##F=QE## so the field strength has to vary inversely with the distance.
The analogy with the ramp is that the total amount of energy needed to push an object to the top of the ramp depends only on the height (##W=mgh##). But a gentle ramp allows you to use a weaker force over a longer distance to end up with the same amount of ##W=Fd## work done.
Likes davenn and PainterGuy
Thank you, both of you!
Regarding the 'field outside', don't forget edge effects. To mitigate those, you may need 'guard rings'...
Related to Electric field outside a parallel plate capacitor
1. What is an electric field outside a parallel plate capacitor?
An electric field outside a parallel plate capacitor is a region in space where electrically charged particles experience a force. It is created by the presence of two parallel plates with opposite charges, with the electric field lines running perpendicular to the plates.
2. How is the strength of the electric field outside a parallel plate capacitor calculated?
The strength of the electric field outside a parallel plate capacitor is calculated using the equation E = Q/εA, where Q is the charge on the plates, ε is the permittivity of the medium between the plates, and A is the area of the plates.
3. Does the electric field outside a parallel plate capacitor depend on the distance from the plates?
Yes, the electric field strength outside a parallel plate capacitor decreases as the distance from the plates increases. This is because the electric field lines spread out as they move away from the plates, resulting in a weaker field.
4. How does the electric field outside a parallel plate capacitor change when the distance between the plates is increased?
When the distance between the plates of a parallel plate capacitor is increased, the electric field strength outside the capacitor decreases. This is because the electric field lines have a longer distance to spread out, resulting in a weaker field.
5. Can the electric field outside a parallel plate capacitor exist in a vacuum?
Yes, the electric field outside a parallel plate capacitor can exist in a vacuum. The electric field is created by the presence of charges on the plates, not by the medium between the plates. Therefore, the electric field will exist even in a vacuum.
