JNBirDy
- 38
Suppose there is a "slab" of plasma in a gas, and let N be the density of free electrons/unit volume. If an external electric field is applied, all the electrons move upwards a distance of x, which produces a thin sheet of unbalanced negative charge -Nex per unit area at the top of the slab. This also leaves a sheet of unbalanced positive charge +Nex per unit are at the bottom.
i) Calculate the resulting electric field produced by the two sheet charges. In addition, calculate the restoring electric force it applies to a typical electron in the slab. Also show that after the external field is shut of the equation of motion of the electrons can be shown as:
d^2x/dt^2 = -(Ne^2)(x) / m[itex]_{e}[/itex]ε₀
ii) Explain why that after the external electric field is turned off the electrons undergo simple harmonic motion, and determine its frequency.
I believe the electric field produced by an sheet of charge is: E = σ/2ε₀
F = E / q
F = ma
Not exactly sure how to start part i)...
If E = σ/2ε₀, would that mean that E = -Nex/2ε₀ for the top and E = Nex/2ε₀ for the bottom? With the electric forces being F = -Ne^2x/2ε₀ and F = Ne^2x/2ε₀?
Any help is appreciated...
