boiteporte
- 8
An electron is traveling through a magnetic field B=(Bx, By, Bz). Find an expressions for the electric field E required to keep the electron's velocity constant at v=(0,vy,0). Hence, show that E and B are perpendicular.
F=q(v cross B)
F=qE
Ok, I totally messed up this question. That's for sure. First, I decided to set the two forces equal to each other using q=-e since it is an electron. So, -e(v cross B)=eE (There are no minus signs on the right hand side, since it is going in the opposite direction).
So, E= -(v cross B). Then I had absolutely no idea what to do so the rest is probably wrong but, that's what I did (I decided to split it up in the 3 components) :
For the x-component, I got Ex=-(-vy*Bz)=vy*Bz
For the y-component, I got Ey=0
For the z-component, I got Ez=-(vyBx)=-vyBx
So, putting them altogether gives E=(vyBz,0,-vyBx). I don't think this answer is right though...
For the second part of the question, I said that the force is perpendicular to the magnetic field (as shown by the Lorentz Force equation) and since the force is parallel to the electric field, then the electric field is perpendicular to the magnetic field. I know there is a way to show it using Maxwell's Equation but the way the question is written implies that I have to use my previous answer. But I'd like some help please...
