Graduate Electric field vs coupling between transmission lines
The discussion revolves around deriving an equation that relates the electric fields of three coupled transmission lines and their mutual capacitances. The user is exploring how the electric field distribution changes as the distance between the lines decreases, leading to stronger coupling and a potential reduction in the electric field of the middle line. Various methods, including Laplace's equation and modeling the structure as a two-port network, are suggested to analyze the electric field interactions and capacitance. The importance of considering both capacitive and inductive coupling in AC scenarios is emphasized, along with the need for boundary conditions in numerical solutions. The conversation highlights the complexity of accurately modeling the electric fields and capacitances in coupled transmission lines.
Young_Scientist23
TL;DR
Derivation of equation which correlate electric fields of coupled lines with coupling. The question is: what will happen with electric field between line and ground plane in scenario, where coupling is strong.
Hello All,
I'm trying to create equation which can describe relation between electric fields of three coupled-lines and coupling between them. Let we say that, we have thee lines having infinit length which are placed above ground plane in distance h. The distance between coupled lines is marked as [l]d[/l]. Each line has defined electric potential (e.g. line no. 1 has potential ##V_{1}## and so on). Now what I'm trying to do. I'm trying to create equation which can correlate mutual capacitances (##C_{12}##, ##C_{23}##) between the lines, with their electric fields (existing between the lines and ground plane - ##\vec{E_{1}}\\##, ##\vec{E_{2}}##, ##\vec{E_{3}}##). It is quite intuitive that, when you decrease distance between the lines, the electric field around middle line no. 2 will be more "concentrated" between the lines nor the ground plane. Moreover, I'm observing it in some simulations and capacitance matrices. I'm just wondering how to proof that mathematically.
I take Laplace to start solving this case, however I'm not quite sure whether it is good way to solve the issue. For this case I derive folowing equations:
$$\frac{d^2V_{1}(x)}{dx^2} - C_{12}\frac{d^2V_{2}(x)}{dx^2} = 0$$, $$\frac{d^2V_{2}(x)}{dx^2} - C_{12}\frac{d^2V_{1}(x)}{dx^2} - C_{23}\frac{d^2V_{3}(x)}{dx^2} = 0$$, $$\frac{d^2V_{3}(x)}{dx^2} - C_{23}\frac{d^2V_{2}(x)}{dx^2} = 0$$.
When I'm trying to solve the second equation in terms of distribution of electric fields and mutual capacitances, I'm "landing" in this equation:
$$\vec{E_{2}} = (\vec{E_{1}} + \vec{E_{3}})C_{mut} $$
where ##C_{mut} = C_{12} = C_{23}##.
Assuming that the electric fields of lines no. 1 and no. 3 are constant, the electric field ##\vec{E_{2}}## of line no. 2 decrease only, when distance between lines is increasing, what has no sense. What I'm doing wrong ? Could someone come up with the correct thought ?
Best Regards,
Tom
Are you only considering DC, static electric fields ?
If so, for more than two conductors, the polarity "mode" will be important.
I think we need a diagram of the physical arrangement you are considering.
Within AC transmission lines, coupling is dominated by the magnetic interaction between the line currents.
I'm considering AC in really high frequencies. I'm sending some figure in attachment. I'm trying to describe coupling between lines by using mutual capacitances between the lines.
With d and h << λ;
Are you studying the cross-talk between quite independent signals, or is this a three-phase supply, in which case the phase of the signals is important?
With d and h << λ;
Yes.
Well, actually I'm not focusing on this case in terms of signal integrity,signal processing. Let we say that, I'm supplying obły the middle line (the "outside " lines - 1 and 3 are not polarized). My intuition and simulations are telling me that, the reduction of distance will change distribution of electric field in this structure. The closer will be the lines, the stronger coupling between them and smaller will be electric field of line 2 to the ground plane. I also assuming that, widths of lines 1 and 3 are greather than line 2. Therefore, electric fields of those lines (to the ground plane) will be quite large.
I prepared addition figure:
On the left we have case in which all coupled lines are in some relativelly large distance to each other. The electric field $$E_{2}$$ is existing in this case. However, if you decrease distance between the lines, the mutual electric fields are increasing what leads to decreasing of the field E2 which can be even equal to zero. My intuition is seying that this has sense, because concentration of electric fields between the lines can compensate field od middle line (E2). However, I don't know how to describe this fact with math.
Regards,
In order to change the voltage on the capacitance between conductors, a current must flow, that will generate a magnetic field. What you are describing as an AC field on a capacitor, is actually a transmission line.
The conductive ground-plane will form a mirror. The structure above the ground will appear as an image, below the ground. The ground disappears, to become a plane of symmetry.
You have not specified a supporting dielectric between the ground plane and the tracks.
You are right that, those lines can be treated as transmission lines. However, according to the theory, such a structures can be modeled by its self-capacitances (capacitances between conductors and ground plane), coupled by mutual capacitances. For calculations we can assume dielectric permitivity equal to 1.
Yet at the same time, it must be modelled as having mutual and self inductance that support travelling waves on the structure.
Ok, but how to derive relation between coupling/mutual capacitance/electric field between the lines and self-capacitance/electric field between middle line and ground plane ? How to start with it ? What I have to use ? Laplace, telegrapher's equation....????
Define the structure as a two port network. Then model the network between the ports. The capacitive electric coupling cannot be modelled without the inductive magnetic coupling.
The impedance of the ports, and the time delay through the network, are related to, the inductance per unit length, and the capacitance per unit length.
I've to model it as a two port network, even if I'm feeding only one port ? I'm just wondering how to solve this problem (how to calculate electric fields distribution) by using some method from EM field theory.
As it is a transmission line, it must have two ports. It can be terminated at the second port with its characteristic impedance, to prevent reflections. That makes it a one port impedance.
To map the electric field within the line, look at the cross-section and make the ground plane a zero equipotential. Assume DC, say 100 volt, on the central line. What is the voltage on the outer two lines?
You can then solve analytically for the static electric field.
Where it is open to infinity, you must establish boundary conditions before solving it numerically by relaxation or the exodus method.
  • · Replies 18 ·
  • · Replies 29 ·
