Electric Fields from Linear Charges
In summary, to find the point charge that will make the electric field at the center of the circle 0, you must include the "annoying" ##\sin\theta## term when integrating over the semi-circle of charge.
Mark Zhu
32
Am amount of charge Q is uniformly spread over a semi-circle of radius R whose center is located a distance A from the origin. What point charge would have to be placed at the origin so that the E field at the center of the circle is 0? (The open end of the semi-circle is facing away from the origin, and is symmetric about the x axis).
E = (k*q)/(r^2)
λ = Q/(pi*R)
λ = dq/ds
ds = R*dθ
First we break up the entire line of charge into tiny bits of charge 'dq'. We look at a single 'dq' and consider the tiny charge's contribution to the electric field at point 'A' (the center of the semi-circle) in the x and y directions. We integrate 'dEx' and 'dEy' both with respect to 'θ' over the entire semi-circle of charge. Of course, we have to first do a series of substitutions for some of the variables using the above "relevant equations", before we can actually do the two integrations. Then we get 'Ex' and 'Ey', and all is well.
My question is since in this problem 'Ey' turns out to be zero due to symmetry, and so 'Ex' equals 'E', do we even need to break up 'dE' into its x and y components? If not, then in the integral of 'dEx' we could leave out the annoying 'sin θ' thus simplifying the calculation.
You can invoke symmetry and that should be sufficient. However, you can also do the integral for Ey formally and verify that it is zero. Either way is correct.
You must include the "annoying" ##\sin\theta## to get ##E_x ~ .##
Likes Delta2
tHANKS FOR THE HELPFUL POST!
You must include ##\sin\theta## to get the correct expression for ##E_x##. The correct contribution to ##E_x## from each dq includes the ##\sin\theta## term, otherwise you would integrating the wrong contribution from each dq and thus you would getting the wrong result for ##E_x##.
Because the contributions to ##E_y## sum up to zero due to symmetry, this doesn't give you the right "to transfer" the ##E_y## contributions to ##E_x## contributions and thus omit the ##\sin\theta## term.
Likes Mark Zhu and SammyS
Thank you for all your great help guys, I understand it now.
oh
Likes SammyS
Tip: Doing this in polar coordinates should help. After you've cart bashed it, try by polars too.
Related to Electric Fields from Linear Charges
1. What are electric fields from linear charges?
Electric fields from linear charges refer to the force that a stationary charged particle experiences when placed in the vicinity of a linearly charged object.
2. How are electric fields from linear charges calculated?
Electric fields from linear charges can be calculated using Coulomb's law, which states that the magnitude of the electric field is directly proportional to the magnitude of the charge and inversely proportional to the square of the distance between the two charges.
3. What is the direction of the electric field from a linear charge?
The direction of the electric field from a linear charge is always perpendicular to the line connecting the charged particle to the linearly charged object. This means that the electric field will either point towards or away from the linear charge, depending on the sign of the charge.
4. How does the distance from a linear charge affect the electric field?
The electric field from a linear charge decreases as the distance from the charge increases. This is because the electric field is inversely proportional to the square of the distance between the two charges. Therefore, as the distance increases, the electric field decreases.
5. What is the difference between electric fields from linear charges and point charges?
The main difference between electric fields from linear charges and point charges is that linear charges have a constant charge density along their length, whereas point charges have a single, concentrated charge at a specific point. This means that the electric field from a linear charge is dependent on both the distance and the length of the charge, while the electric field from a point charge is only dependent on the distance.
