Electric fields + magnets = ouchies
In summary, an electron has a velocity of 1.80 km/s (in the positive x direction) and an acceleration of 2.00 x 10e12 m/s2 (in the positive z direction) in uniform electric and magnetic fields. If the electric field has a magnitude of strength of 25.0 N/C (in the positive z direction), determine the following components of the magnetic field. (x,y,z)
Poop-Loops
732
Hi everyone, I just found this forum and am happy I did, being the only physics major in my physics 200 classes (community college :( ), I feel kind of isolated. Groups of people talking about computer science classes, engineering, and I'm alone, and my instructor/advisor still asks me everytime if I want to major in physics, even though I've said yes like 3 times now. It's just nice to have some people who have been there and done that to talk to. :)
Anyway, on to my question.
An electron has a velocity of 1.80 km/s (in the positive x direction) and an acceleration of 2.00 x 10e12 m/s2 (in the positive z direction) in uniform electric and magnetic fields. If the electric field has a magnitude of strength of 25.0 N/C (in the positive z direction), determine the following components of the magnetic field. (x,y,z)
Now, I don't want any numbers, just some hints on how to get started. I assume the magnetic field is going in an angle betweent he x and y axis, no z axis. I see the electric field, so I want to get rid of it by finding out its contribution, and attributing the exact opposite for magnetic field to get the 2e12, but I get a force to the 20th power, and an acceleration to the 50th power. I've just started magnetism, so I don't know if magnets that can do that are everyday things (I assume not :p), but it seems wrong.
Thanks in advance
PL
F = q(E + v x B)
ma = q(E + v x B)
You are given a, E, and v, and m and q are physical constants you can easily look up, so you just have to solve for B.
In case you don't get the above, F is the net force, which you know is mass times acceleration. But you know that the total force is simply the magnetic force and the electric force. The electric force is simply qE, and the magnetic force, you should know, is qv x B, so qE + qv x B = q(E + v x B). Now, since v x B is a cross product, and there's no inverse for it (i.e. you can't just divide away the v somehow to isolate B, you will have to write B as (Bx, By, Bz), compute the cross product of that with the given v, and you'll have a vector equation (which is really like three equations, since the x, y, and z components are independent), and three unknowns (Bx, By, and Bz). Solve for these, and you're done.
Cross Product?
I don't recall learning this. I definitely haven't done matrices.
If you mean this thing:
Cx = AyBz - AzBy
Cy = AzBx - AxBz
Cz = AxBy - AyBx
Then I don't understand, since I only have v in the x direction, and no B in the z direction. That only gives me Cz = AxBy.
PL
Yea what you have there is correct for the 3 formulas.
...but I get the wrong answer...
PL
Poop-Loops said:
Cross Product?
Cx = AyBz - AzBy
Cy = AzBx - AxBz
Cz = AxBy - AyBx
PL
Yes, that is the cross product of the two vectors <Ax, Ay, Az> and <Bx, By, Bz>. If A is the electric field then you are told that A is the z direction (not x) so Ax= Ay= 0.
I don't see how you decide that there is "no B in the z direction". Bz is one of the things you want to find.
Since Ax= Ay= 0, A X B= C= <-AzBy, AzBx, 0>
Well, seeing as how the acceleration is in the z direction, I don't see how the magnetic field could be going there as well.
A is supposed to be velocity in the x dirction, B would be magnetic field.
So Ax = 1800m/s, Ay = Az = 0
PL
I hate to bump, but I'm really having problems with this well, problem. :)
PL
Ok, I made a breakthrough, and solved for Bz and By (finally understanding how this is supposed to work), but now I don't know how to find Bx, since Bx is always paired with a velocity that is 0.
PL
Oh, apparently you CAN'T determine it (or at least with my limited math knowledge), so "undetermined" is the answer.
Thanks for your help guys, I think I'll stick around here. This forum will probably help me get through a lot of tough times in my physics education career. :)
PL
FAQ: Electric fields + magnets = ouchies
What is an electric field?
An electric field is a physical field that surrounds an electrically charged object and exerts a force on other charged objects within its vicinity. It is represented by lines of force that point in the direction of the force exerted on a positive charge and away from a negative charge.
What is a magnet?
A magnet is a material or object that produces a magnetic field. It has two poles, north and south, which attract or repel other magnets and magnetic materials.
How do electric fields and magnets interact to cause "ouchies"?
When an electric field and a magnetic field are combined, they can exert a force on charged particles, such as the ions in our body. This force can cause the particles to move, creating a sensation of "ouchies" or pain.
Can electric fields and magnets be harmful?
Yes, electric fields and magnets can be harmful if they are too strong or if we are exposed to them for a prolonged period of time. They can disrupt the functioning of our cells and nervous system, leading to adverse health effects.
How can we protect ourselves from electric fields and magnets?
To protect ourselves from electric fields and magnets, we can limit our exposure to them by avoiding strong magnetic fields and keeping a safe distance from electrical devices. We can also use protective equipment, such as shielding materials, to reduce our exposure to these fields.
