Electric Fields: Thin wire in conducting cylinder
In summary, the electric field inside a conductor is zero because the free like charges repel each other to the periphery and arrange themselves for lowest energy state. The charge on the conductor won't go through the space between it and the cylinder, but the charge on the shell will move to cancel the field of the charge on the surface of the wire.
wannabee_engi
Hello PF, I am having a bit of difficulty understanding this question.
"A thin wire with linear charge density λ is surrounded by a conducting cylindrical shell."
(There is a hollow cylinder with a wire though it)
"If the electric field must be zero inside a conductor, is the electric field due to the wire shielded from extending beyond the conducting shell?Find the electric field as a function of distance r from the thin wire."
EA = Qenc0
Q = P/V
surface area (A) = 2πrl
I'm having more conceptual difficulty with this question than mathematical. There is a charged wire in a conductor, but the inside of the conductor must have an E field of zero (at equilibrium). How does this happen? How does the charge on the conductor rearrange or move to cancel the E field? Do I assume the charge can't leave the wire?
To find the E(r) I would just use a Gaussian surface at different intervals (I know it's zero until r>R of cylinder). After that the Q enclosed is just constant from the surface of the cylinder shell.
Thanks for the help.
Hi wannabee_engi, Welcome to Physics Forums.
The electric field inside a conductor is zero because the free like charges repel each other to the periphery and arrange themselves for lowest energy state. Effectively this means that all the fields from the charges balance each other and cancel inside the conductor. Likewise charges in a conductor will rearrange themselves to cancel an externally applied field. Consider: if a field existed inside a conductor (where there are mobile charges), the potential difference caused by that field would cause the mobile charges to flow as a current. Current stops when the charges can go no further (can't escape the surface), and they "pile up" and create their own field to dissuade further charges from approaching. That is, they cancel the external field within the space of the conductor.
Now, this can happen inside a conductor where there is a path for charges to follow. In you wire+cylinder case there is free space between the wire and cylinder where charges cannot flow. So you can expect the charges on the wire to live on the surface of the wire, and their electric field to extend across the gap to the inner surface of the cylinder. So there will be a field in that gap. That field in turn will cause charges to rearrange themselves in the cylinder (which is also a conductor).
What you have is what is called a cylindrical capacitor. A web search will turn up details about the charge distribution and fields.
Likes wannabee_engi
Ok, I understand the idea of what you are saying. The charge on the wire won't go through the space between it and the cylinder, but the charge on the shell will move to cancel the field of the charge on the surface of the wire. It's tough to conceptualize this stuff from the textbook. Thanks for the response.
I don't see why there wouldn't be fringing effects at the ends of the shielded wire, assuming the ends of the shield are not sealed. Finding the axial E field close to either end would seem a tough assignment. Maybe I'm misinterpreting the question.
Hello, thank you for your question. It seems like you are on the right track with your understanding of the concept of electric fields in conductors. Let me try to explain it further.
Firstly, it is important to understand that in a conductor, the free charges (electrons) are able to move freely and redistribute themselves to cancel out any external electric field. This is because they are not bound to any specific atom or molecule, unlike in an insulator. This redistribution of charges is what results in an electric field of zero inside the conductor.
Now, in the case of a thin wire surrounded by a conducting cylindrical shell, the wire itself will have an electric field due to the charges on it. However, as you correctly mentioned, the charges on the cylindrical shell will redistribute themselves to cancel out this electric field inside the conductor. This means that the electric field due to the wire is indeed shielded from extending beyond the conducting shell.
To find the electric field as a function of distance r from the thin wire, you can use the equation E = Qenc/ε0A, where Qenc is the charge enclosed by the Gaussian surface, ε0 is the permittivity of free space, and A is the surface area of the Gaussian surface. As you mentioned, the charge enclosed is constant after r>R, so you can use this equation to find the electric field at different distances from the wire.
I hope this helps to clarify your understanding of electric fields in conductors. Keep up the good work!
Related to Electric Fields: Thin wire in conducting cylinder
1. What is an electric field?
An electric field is a physical quantity that describes the influence of electric charges on each other. It is a vector quantity that has both magnitude and direction.
2. What is a thin wire in a conducting cylinder?
A thin wire in a conducting cylinder refers to the setup where a thin wire, carrying an electric current, is placed inside a hollow cylinder made of a conducting material. The wire and the cylinder form a simple circuit.
3. How is an electric field generated in this setup?
When an electric current flows through the thin wire, it creates a magnetic field around it. This magnetic field then induces an electric field in the conducting cylinder, as per Faraday's law of induction.
4. What are the practical applications of this setup?
This setup is used in various devices such as transformers, electric motors, and generators. It is also used in medical equipment, particle accelerators, and other scientific experiments.
5. How does the electric field affect the wire and the cylinder?
The electric field causes the charges in the wire to move, creating an electric current. In the cylinder, the induced electric field causes the charges to redistribute, resulting in an opposite electric field that cancels out the original field inside the conductor. This allows the current to flow smoothly through the wire without creating a buildup of charge in the cylinder.
