Electric flux and electric fields
In summary, the problem involves finding the magnitude of the electric field at a point inside a solid metal sphere with a net charge of 0.130 nC and a radius of 0.900 m. Using the equations for electric flux and charge, the electric field is calculated to be 1.28217 N/C at a point 0.100 m below the surface. This indicates that a charged conductor under electrostatic equilibrium will have a constant electric field within it.
aiaigasa
Hi, I'm having a bit of trouble with the following problem. Any insight as to what I'm doing wrong?
A solid metal sphere with radius 0.900 m carries a net charge of 0.130 nC. Find the magnitude of the electric field at at a point inside the sphere, 0.100 m below the surface.
[tex]\Phi = \int\vec{E}\cdot\vec{A} = \frac{Q}{\epsilon_{0}}[/tex]
[tex]Q = \frac{0.130 \times 10^{-9}}{\frac{4}{3}\pi(0.9)^{3}} \times \frac{4}{3}\pi(0.8)^{3} = 9.13032 \times 10^{-11}[/tex]
[tex]\Phi = \frac{9.13032 \times 10^{-11}}{\epsilon_{0}} = 10.3119[/tex]
[tex]E = \frac{\Phi}{A} = \frac{10.3119}{4\pi(0.8)^{2}} = 1.28217 \frac{N}{C}[/tex]
What can you deduce about a charged conductor under electrostatic equilibrium?
Hello, it seems like you are trying to solve the problem using the electric flux equation. However, this equation is used to calculate the total electric flux through a closed surface, not the electric field at a specific point. To find the electric field at a point inside the sphere, you can use the equation:
E = \frac{kQ}{r^2}
Where k is the Coulomb's constant (8.99 x 10^9 Nm^2/C^2), Q is the net charge of the sphere, and r is the distance from the center of the sphere to the point where you want to find the electric field. In this case, r = 0.1m. Plugging in the values, we get:
E = \frac{(8.99 \times 10^9)(0.130 \times 10^{-9})}{(0.1)^2} = 9.167 \times 10^3 \frac{N}{C}
This is the magnitude of the electric field at a point inside the sphere, 0.1m below the surface. I hope this helps!
FAQ: Electric flux and electric fields
What is electric flux?
Electric flux is a measure of the electric field passing through a given surface. It is represented by the symbol Φ and is measured in units of volt-meters (V*m).
What is the equation for electric flux?
The equation for electric flux is given by Φ = E * A * cosθ, where E is the electric field, A is the area of the surface, and θ is the angle between the electric field and the normal vector to the surface.
How is electric flux related to electric fields?
Electric flux is directly proportional to the strength of the electric field passing through a given surface. This means that as the electric field increases, the electric flux also increases.
What is the SI unit for electric flux?
The SI unit for electric flux is volt-meters (V*m). However, it is sometimes also expressed in units of newton-meters squared per coulomb (N*m^2/C).
What is the difference between electric flux and electric field?
Electric flux is a measure of the electric field passing through a given surface, while electric field is a measure of the force that a charged particle experiences at a specific point in space due to the presence of other charged particles. Electric flux is a scalar quantity, while electric field is a vector quantity.
