Electric flux through a hemisphere
In summary: would need to choose one side of the surface as the positive side, and then follow the convention that the differential area vector points outward from that side.
Loopas
55
During my physics lecture, the professor said that flux on a closed surface is equal to zero. What exactly is a closed surface defined as?
This problem also requires the use of the Flux = Field * Area formula. In relation to the direction of the electric field, what is the area for Part B? I'm just having trouble understanding the importance of closed surfaces vs. non-closed surfaces and how to tell them apart. Thanks
Flux through a surface is more generally defined as ##\phi_E = \int_S \mathbf{E} \cdot \mathbf{dS}##, so it is the integral of the normal component of ##\mathbf{E}## over the surface ##S##. This surface ##S## will have a boundary curve if it is an open surface (and in your example, this boundary curve is a circle.) By virtue of Stokes', the flux through any surface with the same boundary curve will be the same.
That's true of electric flux, *if* there is no charge inside the closed surface.
If you have a charge or charges completely surrounded by a closed surface, the electric flux through the closed surface is proportional to the total amount of charge contained within.
Any shape you can imagine that completely surrounds and contains a volume.
A closed, six-sided box is a closed surface as an example. A sphere is a closed surface, if the sphere doesn't have any holes in it.
Any three dimensional shape you can imagine is a close surface as long as that shape completely encloses some sort of volume without having any holes in it.
Take the box, and remove one of its sides (making it a 5-sided, open box), and it is no longer a closed surface.
Take a sphere and poke a hole in it, or cut it in half as is done in this problem, and it is not a closed surface.
There is a convention that the differential surface vector of a closed surface always points "outward" (as opposed to pointing inside). That's merely a convention though.
There is no such convention for open surfaces though, and you'll have to arbitrarily choose which side of the surface is positive on a case by case basis.
This part is slightly tricky. But the answer is easy once you develop an intuition about it. I'd like you to think about this one. So I won't give any detailed hints.
Just choose which side of the surface is positive or negative, and once you choose it be consistent. Keep in mind a flux line passing though the surface in one direction cancels out a flux line passing through the surface in the opposite direction.
(In terms of differentials, the differential area vector is always perpendicular to the plane of the differential surface. But you will still have to choose which side is positive and which side is negative, and then maintain consistency.)
And one last clarification,
Keep in mind that that's not a multiplication sign in the formula. That's the vector dot product! It makes a difference. :smile:
Take an open, flat surface with area A and a uniform electric field E and the flux is
[tex] \Phi_E = \vec E \cdot \vec A [/tex]
Note the vector notation. Converting that to scalars,
[tex] \Phi_E = E A \cos \theta[/tex]
where [itex] \theta [/itex] is the angle between the surface vector (perpendicular to the surface) and the electric field direction.
More generally, with curved surfaces (as CAF123 points out), that becomes,
[tex] \Phi_E = \int_S \vec E \cdot \vec {dA} [/tex]
So the convention of flux depends on the direction of surface vectors? I think I understand... that would mean that any flux entering the top of the sphere perpendicular to the axis is canceled when passing through the bottom of the sphere, since each surface that the E-field lines pass through have a different convention?
Thanks for your help by the way
Yes, that's right!
Not because of different conversions. The convention must be the same for all points on the surface.
For example, you can choose the convention that the surface vector always points outward, from hemisphere's center of curvature. Or alternately, you can choose the different convention that the surface vectors point toward the center of curvature. Your convention must be such that the vector is perpendicular to the differential surface, but you'll always have two choices: the top side or the bottom side. Once you choose, consistency must be maintained.
The overall flux is zero in Part B) because for every E(dA)cos(θ) passing through the surface from the outside -> in, there is another -E(dA)cos(θ) passing from the inside -> out. In this situation there are no lines of flux that only pass through the surface in one direction.
Ahh ok I see now, thank you for your help!
FAQ: Electric flux through a hemisphere
What is electric flux through a hemisphere?
Electric flux through a hemisphere is the measure of the total electric field passing through the curved surface of a hemisphere. It is a measure of the number of electric field lines passing through the surface.
How is electric flux through a hemisphere calculated?
The electric flux through a hemisphere can be calculated by using the formula Φ = E * A * cosθ, where Φ is the electric flux, E is the electric field strength, A is the area of the curved surface, and θ is the angle between the electric field and the normal vector of the surface.
What factors affect the electric flux through a hemisphere?
The electric flux through a hemisphere is affected by the strength of the electric field, the area of the curved surface, and the angle between the electric field and the normal vector of the surface. It is also affected by the dielectric constant of the material inside the hemisphere.
What is the unit of measurement for electric flux?
The unit of measurement for electric flux is the volt-meter (V*m), which is equivalent to the unit of electric potential multiplied by the unit of area.
Why is electric flux through a hemisphere important?
Electric flux through a hemisphere is an important concept in electromagnetism as it helps in understanding the behavior of electric fields and their interactions with different surfaces and materials. It is also used in various applications such as in calculating the electric field strength inside a capacitor or in designing electromagnetic devices.
