Electric Force on a charge effected by a non-uniform linear charge
In summary, the question asks what the force on a charge at 3d z is if the charge is located at an insulator which lies between -d\hat{z} and d\hat{z}. The problem is that the person is having trouble with one part of the integral- the r^{2} in the denominator. They ask for help and I provide a summary of the problem and a solution.
bjornert
Ok, so here's the question. I've pretty much got it except I'm having trouble with one part of constructing the integral. The problem is...
An insulator which lies between the positions -d[tex]\hat{z}[/tex] and d[tex]\hat{z}[/tex] has a nonuniform linear charge density [tex]\lambda[/tex] = [tex]\lambda_{o}[/tex][tex]\frac{z}{d}[/tex] . Find the force on a charge 'q' located at 3d[tex]\hat{z}[/tex].
[tex]\int[/tex] d[tex]\vec{E}[/tex] = [tex]\int[/tex][tex]\frac{k dq}{r^{2}}[/tex][tex]\hat{z}[/tex]
dq = [tex]\lambda[/tex]dz
What I ended up getting when constructing the integral is...
[tex]\int[/tex][tex]^{ d}_{-d}[/tex]k[tex]\frac{\lambda_{0} z dz}{d r^{2}}[/tex][tex]\hat{z}[/tex]
Now I'm having trouble with the r[tex]^{2}[/tex] part in the denominator...I know it should be something like...
(r [tex]\pm[/tex] something)[tex]^{2}[/tex]
...but I'm just not sure what it is...any help would be greatly appreciated.
Thanks!
what is d?
d is the length of the insulator (from -d to d), as stated in the question.
okay I see what you want I think. Both the point that you are trying to find the force on, and the insulator are parallel?
And does the sign on the charge change at the origin? Or is it just the magnitude of the distance from the origin that matters for the charge?
not exactly, the point and the insulator are both on the same axis...the insulator spans (-d) to (d) and the point is at 3d all along the z axis (z-hat)
also yes, the charge density is non uniform so it changes at the origin as you stated...lambda z/d changing sign as a function of it's position on the z axis.
i would do two separate integrals. the first being from -d --> 0.
your integral looks good. I would just put on the denominator (4d + z)^2
and when it goes from 0 ----> d, put on the bottom (3d -z)^2
but makes sure from -d ---> 0 you have the -z value subbed in.
whoops it seems i have done that wrong. (3d-z)^2 will work for it all. forget about (4d + z). So I might still do the two integrals seperately, but they should have the same denominator.
ok, i think i got it now...
[tex]\int^{d}_{-d}[/tex][tex]\frac{k\lambda_{o}zdz}{d(3d-z)^{2}}[/tex]
and then removing constants...
[tex]\frac{k\lambda_{o}}{d}[/tex][tex]\int^{d}_{-d}[/tex][tex]\frac{zdz}{(3d-z)^{2}}[/tex]
but still the integral doesn't turn out nicely...should i be using the length of the vector r
|[tex]\overline{r}[/tex]| = [tex]\sqrt{(3d)^{2} - (z)^{2}}[/tex] ?
if i run it through all the way with the |[tex]\overline{r}[/tex]| i end up with a nice integral that i can substitute and the resulting field at 3d ends up being zero...it seems reasonable enough but is it right...i don't know...?
i'm relatively happy with that answer so if you see something fundamentally wrong with it you can let me know...otherwise thanks for you help!
it can't be zero if i understand the charge density properly. Did you try two integrals, one from -d to 0 and one from 0 - d?
it can't be zero. do the integral with (3d - z)^2 on the bottom. i got k*lambda/d(3/4 + ln(1/2))
ok, yeah got it now...thanks
FAQ: Electric Force on a charge effected by a non-uniform linear charge
1. What is the equation for calculating the electric force on a charge affected by a non-uniform linear charge?
The equation for calculating the electric force on a charge due to a non-uniform linear charge is F = k * q * (Q1 / r1^2 + Q2 / r2^2 + ... + Qn / rn^2), where F is the force, k is the Coulomb's constant, q is the charge of the test charge, Q1-Qn are the charges of the individual segments of the linear charge, and r1-rn are the distances between the test charge and the segments.
2. How does the electric force vary along a non-uniform linear charge?
The electric force varies along a non-uniform linear charge because the electric field strength varies at different points along the charge. The electric field strength is directly proportional to the electric force, so where the field is stronger, the force will also be stronger.
3. What is the direction of the electric force on a charge due to a non-uniform linear charge?
The direction of the electric force on a charge due to a non-uniform linear charge depends on the charges of the individual segments and their positions relative to the test charge. The force will be attractive if the charges have opposite signs, and repulsive if the charges have the same sign.
4. How does the distance between the test charge and the linear charge affect the electric force?
The distance between the test charge and the linear charge has an inverse square relationship with the electric force. This means that as the distance increases, the force decreases, and vice versa. So, the closer the test charge is to the linear charge, the stronger the electric force will be.
5. How does the magnitude of the charges on the linear charge affect the electric force on a test charge?
The magnitude of the charges on the linear charge has a direct relationship with the electric force on a test charge. This means that as the charges on the linear charge increase, the force on the test charge will also increase. So, the greater the magnitude of the charges, the stronger the electric force will be on the test charge.
