Electric, magnetic, and electromagnetic fields
In summary: Electric field: a 3-vector: (Ex, Ey, Ez)Magnetic field: a 3-vector: (Bx, By, Bz)Electromagnetic field: a 2-form (with 6 components): (Ex, Ey, Ez;Bx, By, Bz)a tensor?a tensor?Yes, any 2-form can be represented by an antisymmetric second-order tensor.But a 2-form is easier because:i] it has only 6 components, while the tensor has 16 components, 4 of which are 0, and 6 of the remaining 12 are minus the other 6;ii]
holtvg
What are the differences between these three types of fields or are they all interrelated and the same.
just to add, explicitly, that the classical magnetic interaction can be understood as a manifestation of only the electrostatic interaction but with the effects of (special) relativity taken into consideration. i.e. the magnetic field and resulting force on charged particles is essentially nothing new or different than the electric field. but, in classical physics (where there is no SR concepts such as time dilation, etc.), the magnetic field has to be described or modeled as a different or separate action than the electrostatic field.
Welcome to PF!
Hi holtvg! Welcome to PF! :smile:
They are interrelated in the same way that the x and y components of a vector are interrelated … if you rotate the x and y axes, the x and y components of the same vector get mixed together a little.
Similarly, observers with different velocities see the E and B fields mixed together … for example, a stationary electron has an E field and a zero B field, but a moving electron has slightly different E field, and a small B field also. :smile:
(this is not a relativity thing … Maxwell knew all about it!)
a tensor?
granpa said:
a tensor?
Hi granpa! :smile:
ii] it makes many equations much more obvious (in partiuclar, Lorentz force and Maxwell's equations). :smile:
sort of like a pseudovector. a shorthand way of writing a tensor.
Hi granpa! :smile:
Yes, a pseudovector in 3-space (like angular momentum, or any other cross-product of two 3-vectors) is a 2-form , and can be represented as an anti-symmetric tensor. :smile:
(though a pseudovector in 4-space is a 3-form, like current :wink:)
Related to Electric, magnetic, and electromagnetic fields
1. What are electric, magnetic, and electromagnetic fields?
Electric, magnetic, and electromagnetic fields are forms of energy that are created by the movement of charged particles, such as electrons. Electric fields are created by stationary charges, while magnetic fields are created by moving charges. Electromagnetic fields are a combination of electric and magnetic fields, and they can travel through space as waves.
2. How do electric and magnetic fields affect our daily lives?
Electric and magnetic fields are present in many aspects of our daily lives, from the devices we use to the natural world around us. They are essential for the functioning of electronic devices, such as phones and computers. They also play a crucial role in the Earth's magnetic field and the generation of electricity.
3. Are electric and magnetic fields harmful to our health?
There is ongoing research on the potential health effects of exposure to electric and magnetic fields. While there is no conclusive evidence that they are harmful, some studies suggest a possible link between long-term exposure to high levels of electromagnetic fields and certain health conditions. However, the levels of electric and magnetic fields in our daily lives are generally well below the safety limits set by regulatory agencies.
4. How can we protect ourselves from electric and magnetic fields?
To reduce exposure to electric and magnetic fields, it is recommended to keep a safe distance from high-voltage power lines and to limit the use of electronic devices. Shielding materials can also be used to reduce the levels of electric and magnetic fields in specific areas, such as homes or offices.
5. Can we harness electric and magnetic fields for energy?
Yes, electric and magnetic fields can be harnessed to generate electricity. This is the principle behind power plants that use turbines to convert the energy from moving water or steam into electricity. Renewable energy sources, such as solar and wind power, also use electric and magnetic fields to generate electricity.
