Amadeo
- 28
- 9
[/B]
A car battery with a 12v emf and an internal resistance of .040 ohms is being charged with a current of 50A. A.) What is the potential difference across the terminals? B.) The rate of energy dissipation in the battery Pr. C.) the rate of energy conversion to chemical form? D.) When the battery is used to supply a 50A current tot he starter motor, what is V and Pr?
[/B]
V=IR
P=iε
Pd=i^2R
[/B]
for A
I thought that since the emf of the battery is 12 and the potential drop in potential due to the resistor is (50A)(.04ohms) = 2v the total potential across the battery would be 12-2 = 10. However, the book says that it is 14 (which is 12+2). I am not able to figure out why it is plus instead of minus. (Or, if I am correct in thinking that it should be minus in the first place.)
for C:
I thought that the power supplied to the recharge of the battery's chemical energy store would be the total power of the device minus the power dissipated by heat. So, since the total power would be 50(12) = 600w and the power of heat dissipation would be (50)^2(.04) = 100, the power of the recharge would be 600-100 = 500. However, the book says that it is 600.
for D:
I thought that the V would be what it was in part a, namely 10, and for the same reasons. I thought that Pr would be the same as in B, or 100w. These are the answers the book gives.
The only thought I have about the difference between situations in A/B and D would be the direction of the charge flow. But I don't see why a resistance would create an increase in potential just because the current flowed though it form a different direction.
Thank you for your assistance.
