Electric potential and current around an insulator
In summary, the conversation discusses the effects of a crack in a conducting surface on the movement of current. The equations for potential, electric field, and current density are mentioned, and it is noted that the current will not pass through the crack. The question of how the current should move is raised, and it is mentioned that a boundary condition may be needed. The possibility of treating the crack as a radiating dipole is suggested, but it is questioned if this would still apply in the case of a poor conductor with low current.
meldraft
281
Hi all,
I am trying to run a simulation, and I have come across a theoretical question.
Let's say that you have an electric charge producing a potential on a conducting surface (let's assume it's infinite). Now, if you make a crack in the surface so that there is a gap (filled with air for example), you create an area where the current can't pass through.
The equations say that the potential inside the crack will change because of the different electric permitivity, while on the other side it won't be affected at all.
My problem is how the current is supposed to move. If I just integrate for the current density I can get the current vectors on the surface:
[tex]V=\frac{1}{4\pi\epsilon}\frac{Q}{r}[/tex]
[tex]E=-\nabla{V}=\frac{1}{4\pi\epsilon}\frac{Q}{r^2}[/tex]
[tex]J=\sigma E[/tex]
[tex]I=\int{J\cdot dA}[/tex]
, but they look like they would without the crack, with the exception that no current passes through the crack.
Current moves along the electric field, which, in my case, just has a gap where the crack is, and its shape is otherwise unaffected.
I know that current is supposed to go around the crack, much like a fluid would, so I probably need a boundary condition for the crack. Does anybody know how I should go about it?
I fear the answer is more complicated than you are hoping for. If you have currents through a conducting sheet with a hole (crack, gap, slot, etc.), then the hole will http://en.wikipedia.org/wiki/Slot_antenna" . As a first order approximation, you can treat the hole as a radiating dipole oriented perpendicular to the conducting surface and located at the hole's center.
In my problem however, the material is a really bad conductor and the current is very small. Is this still applicable in that case?
FAQ: Electric potential and current around an insulator
What is an insulator?
An insulator is a material that does not easily allow the flow of electric current. This is because it has a high resistance, meaning it does not have many free electrons that can move and carry the current.
How does an insulator affect electric potential?
An insulator does not affect electric potential, as it does not allow the flow of electric current. Electric potential is the measure of the potential energy of a charged particle, and it remains constant in an insulator since there is no movement of charges.
Can electric current flow through an insulator?
No, electric current cannot flow through an insulator. As mentioned before, insulators have a high resistance which prevents the flow of electric current. However, a small amount of current can leak through an insulator due to imperfections in the material or high enough voltage applied.
How is an insulator different from a conductor?
An insulator differs from a conductor in that it has a high resistance and does not allow the flow of electric current. In contrast, a conductor has a low resistance and allows the flow of current. Examples of conductors include metals and human body tissues, while examples of insulators include rubber, plastic, and glass.
Why do insulators have low conductivity?
Insulators have low conductivity because they have tightly bound electrons in their atoms. These electrons are not free to move and carry the electric current, unlike in conductors where electrons are loosely bound and can easily move. Additionally, insulators have a wide energy band gap, which further restricts the movement of electrons.
