Electric potential and voltage in a circuit
In summary: One lead goes to a known source of potential energy, typically the earth's surface. The other lead goes to a resistor that we use to measure voltage. If we connect the two leads together, we get a voltage. If we connect the two leads to different points, we get a potential difference.
FS98
105
As I understand it, electrical potential is the potential energy of a unit charge in some point in space. How does this idea relate to the idea of voltage in a circuit? The term electric potential seems to be used for both.
Voltage is the difference in electric potential between two points, while electric potential itself is a way to define the electric potential energy of any charged particle placed in a specific field. Electric potential is the electric potential energy of a charged particle divided by the charge on that particle. Dividing by the charge gives you a way of characterizing the electric field itself, without need for a specific reference charge.
Basically, a charged particle with 2 coulombs of charge might have 10 joules of electric potential energy when placed in an electric field at point A. Dividing out the charge gives you 5 volts (joules per coulomb) of electric potential. At point B, the same charged particle might have 4 joules of electric potential energy. Dividing the charge out gives you 2 volts.
The voltage between points A and B is 5-2=3 volts. Note that volts is a unit of measurement, while voltage is not.
Likes FS98 and phinds
Potential is Potential.
Potential Difference is Volts.
Say that to yourself every day for a few weeks and you will not be confused.
Think in terms of gravitational potential. Climb up a step ladder 1.5m and jump off. You fell between a Gravitational Potential Difference of 1.5m and it hurt your feet. Now get in a 747 and do the same thing at 10,000m. Your Gravitational Potential is much higher but the Potential Difference and pain is the same.
Isn’t electrical potential already relative? I thought we just generally use infinity as the point we’re comparing to. If that is the case, how is voltage a difference while electrical potential is not?
I'm not going to get into whether or not electric potential is relative. I only meant to point out what the difference between voltage and electric potential are. Perhaps I should have avoided italicizing anything.
Whether or not electric potential is relative, voltage is the difference in electric potential between two points. It represents the amount of energy, per unit of charge, required to move a charged particle between those two points. Electric potential is a measure of the amount of energy required to move a charge from infinity to its current location. However, note that infinity is not a point, though we commonly treat it as if it is. If I were to choose a point 5 gazillion lightyears away as my infinity, I would actually be finding the voltage between that point and the current location of my particle. The reason is because that point, even though it's 5 gazillion lightyears away, still has electric potential.
Likes FS98
The "Potential" is defined relative to infinity. There is no confusion when you quote Potential (appropriately) but there is no experiment on Earth where a voltmeter can be connected to Infinity so the reference always has to be specified. Hence PD.
The system is so well established that there is not much point in questioning it or arguing against it.
Likes FS98
A strictly practical view is to note that a voltmeter that we use to measure voltage always has two wire leads.
Likes sophiecentaur
Related to Electric potential and voltage in a circuit
1. What is electric potential in a circuit?
Electric potential in a circuit refers to the amount of electrical energy that is available to be used by the electrons in a circuit. It is measured in volts.
2. What is the difference between electric potential and voltage?
Electric potential is a measure of the energy available to electrons in a circuit, while voltage is a measure of the force that pushes those electrons through the circuit. In other words, electric potential is the potential energy, and voltage is the measure of how much of that energy is being used.
3. How is electric potential and voltage related in a circuit?
Electric potential and voltage are directly proportional in a circuit. This means that as the electric potential increases, so does the voltage. This also means that if the electric potential decreases, the voltage will also decrease.
4. What is the unit of measurement for electric potential and voltage?
The unit of measurement for both electric potential and voltage is volts (V).
5. How do resistors affect electric potential and voltage in a circuit?
Resistors in a circuit can affect the electric potential and voltage by either reducing or limiting the flow of electrons. This means that resistors can decrease the voltage and electric potential in a circuit. The larger the resistance, the more it will impact the voltage and electric potential in the circuit.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
