Electric potential distance problem?
In summary, to calculate the electric potential difference between two points, you need to use the relationships between voltage (potential energy difference), work, and distance.
virtuoso_735
Hi everyone I need very badly some help with this problem please:
A force of 0.053 N is required to move a charge of 39 µC a distance of 30 cm in an electric field. What is the size of the electric potential difference between the two points?
Is the electric potential difference the force divided by q (whatever that is) divided by distance? That's what someone told me. I can't find q though. Is that even the right way to to it?
I'm not really sure how to do this at all. I tried to do it for more than an hour yesterday but my teacher is TERRIBLE and I don't get it. The book doesn't really help either. Can someone solve it and guide me through it?
Thanks a whole lot!
Thanks a whole lot!
There are a few relationships involving voltage (or potential difference) V. The one you need here is [tex]W = QV[/tex] where V is the potential difference, Q is the charge and W is work done. W is the work required to move a charge Q against a potential difference of V.
Now, use another relationship that you should know between work, force and distance to form an equation and solve for V.
You should probably like to know the actual meaning of voltage. I personally like sentences.
Voltage is the potential energy difference, per unit charge.
Sorry, sorry, sorry. I misread xXPhoenixFireXx's post. I missed the word "energy" in it, I thought he said "potential difference per unit charge" (which would be wrong). My apologies. I've deleted my post.
haha hate it when that happens. I may as well delete mine as well 'cause I don't want to detract from the the purpose of the thread.
Okay thanks.
So exactly is q though? I'm confused. Is it 32 in the problem above or do I need to solve for it? If so what equation do I use?
The charge Q is the 39 micro Coulombs that was given in the question
Thanks. Do I need to conver it?
Yes, you should convert it to Coulombs.
~H
FAQ: Electric potential distance problem?
What is an electric potential distance problem?
An electric potential distance problem involves calculating the electric potential at a specific distance from a charged object. This distance can be either a scalar distance or a vector distance, depending on the problem.
How do I calculate electric potential at a given distance?
To calculate the electric potential at a given distance, you can use the formula V = kQ/r, where V is the electric potential, k is the Coulomb's constant, Q is the charge of the object, and r is the distance from the object.
Can electric potential be negative?
Yes, electric potential can be negative. This occurs when the charged object has a negative charge, and the electric potential at a given distance is negative. It can also occur when the object has a positive charge, but the point where the electric potential is being calculated is at a distance greater than the object's radius.
What is the unit of electric potential?
The unit of electric potential is volts (V). It is a measure of the electric potential energy per unit of charge.
How does distance affect electric potential?
Distance affects electric potential in an inverse relationship. As the distance from a charged object increases, the electric potential decreases. This is because the electric field strength decreases with distance, resulting in a decrease in the electric potential.
