Electric potential energy of the two protons?
In summary, the question asks for the electric potential energy of two protons in the nucleus of a helium atom, which are modeled as point particles separated by a distance of 1.0 fm. The solution would involve using the formula for electric potential energy, taking into account the charges and distance between the protons.
shahin93
The nucleus of a helium atom contains two protons. In a simple model of this nucleus, the protons are viewed as point particles separated by a distance of 1.0 fm (1.0 x 10^-15 m). What is the electric potential energy of the two protons?
please do step by step.
Did you read the forum rules when you signed up? You should follow the posting template. Your attempt at a solution (or at least your thoughts on how to approach the problem) is required so that we can see how to help. We don't do your homework for you here :wink:
Related to Electric potential energy of the two protons?
1. What is electric potential energy?
Electric potential energy is the energy that a charged particle possesses due to its position in an electric field. It is a type of potential energy that is directly related to the electric force between two charged particles.
2. How is electric potential energy calculated for two protons?
The electric potential energy between two protons is calculated using the formula U = k(Q1Q2)/r, where k is the Coulomb's constant, Q1 and Q2 are the charges of the protons, and r is the distance between the two protons.
3. What factors affect the electric potential energy between two protons?
The electric potential energy between two protons is affected by the magnitude of their charges, the distance between them, and the medium in which they are located. It also depends on the direction of the electric field, as it can either add to or subtract from the potential energy.
4. How does electric potential energy change when the distance between two protons is increased?
As the distance between two protons increases, the electric potential energy between them decreases. This is because the electric force between them weakens as the distance increases, resulting in a decrease in the potential energy.
5. What is the unit of electric potential energy?
The unit of electric potential energy is joules (J). It is a derived unit that is equivalent to kg*m^2/s^2 or N*m.
