Electric potential energy problem
In summary, the problem involves two parallel plates with equal and opposite charges and a proton being launched from the negative plate to the positive plate. To find the minimum speed the proton should be launched with, the electric field and potential difference between the plates must be calculated. The electric potential energy at the positive plate can be equated to the kinetic energy at the negative plate. The correct equations and units must be used to solve the problem.
mcano
"Two parallel plates having charges of equal magnitude but opposite sign are separated by 12cm. Each plate has a charge superficial density of 36nC/m2. A proton is launched from the negative plate to the positive plate. What is the minimum speed the proton should be launched to get to the positive plate?"
Well here's the problem, however, there are steps the teacher gave to solve, here are those
1. Express the electric field between the plates as a function of the charge superficial density (done)
2. Express the potential difference between the plates as a function of the charge superficial density(done)
3. Use the conservative nature of the electric fields and find an expression for the initial speed of the proton as a function of the charge superficial density, the distance between the plates and the speed when it gets to the negative plate.(Here is where i have problems)
from 1. we have that
[tex]
E = {\frac{\sigma}{\epsilon_{0}}}
[/tex]
from 2 we have that
[tex]
\Delta V = E.d = {\frac{d\sigma}{\epsilon_{0}}}
[/tex]
Given that the field is uniform, well, I'm considering it uniform since the size of the plates is not stated
Now, we have the kinetic energy
[tex]
K = {\frac{1}{2}}mv^2
[/tex]
and also we have the Torriceli's equation
[tex]
v_{f}^2 =v_{i}^2 + 2ad
[/tex]
Well, given the things before i know i can use the Torriceli's equation and get the expression, however i have no idea of how it would be possible to ge the relation between kinetic and electric potential energy, mostly because I'm not sure what is the equation for the electric potential energy in this exact problem, i have found many equations and my only guess is this:
Assuming that the potential energy at the positive plate (point B) is maximum and assuming that the kinetic energy in the negative plate is maximum (point A), thus at point A electric potential energy is zero
i have this,
[tex]
\Delta V =U_{B}-U_{A} = E.d = {\frac{d\sigma}{\epsilon_{0}}}
[/tex]
And given that at the point A:
[tex]
U_{A} = 0
\rightarrow U_{B} = {\frac{d\sigma}{\epsilon_{0}}}
[/tex]
Then i could do
[tex]
K = U
[/tex]
But I'm not so sure about this, so i was wondering if someone could give me a better explanation
Thanks beforehand
You're headed in the right direction, but you're mixing up electric potential V with electric potential energy U.
So now, i only have to remember that
[tex]
W = -(U_{B}-U_{A}) = -\oint \vec{E}\cdot d\vec{r}
[/tex]
Well considering that in this case F = E
And use the principle of conservation to make K = U and then i can just get the final speed, and replace in the torricelli's equation and replace right?
right?
No, you're still making the same mistake. Check the units of what you wrote. They don't work out.
Yeah, sorry, i forgot that the field is N/C and the Work should be J/m, so first i need to calculate the force that the field is exerting over the particle right? i know the field would be:
[tex]
E = \frac{\sigma}{\epsilon_{0}}
[/tex]
and thus
the force would be:
[tex]
F = q {\vect{E}}
[/tex]
where q would be the charge right?
that would be the proton's charge, now, as i obtain the force i should now integrate to obtain the work right?
[tex]
W = -(U_{B}-U_{A})=-\oint \vec{F}\cdot d\vec{r} = -\oint q\vec{E}\cdot d\vec{r}
[/tex]
Work is in joules, and the integral symbol shouldn't have a circle, which denotes a closed path. The negative sign in front of the integral shouldn't be there either.
Teah, i already worked it out, thanks for your help...
Related to Electric potential energy problem
1. What is electric potential energy?
Electric potential energy is the energy that a charged object has due to its position in an electric field. It is the potential for the charged object to do work.
2. How is electric potential energy calculated?
Electric potential energy is calculated using the formula U = qV, where q is the charge of the object and V is the electric potential at that point in the electric field.
3. What is the difference between electric potential and electric potential energy?
Electric potential is the potential energy per unit charge at a specific point in an electric field, while electric potential energy is the total potential energy of a charged object at a specific point in an electric field.
4. How does distance affect electric potential energy?
The closer an object is to a source of electric charge, the stronger the electric field and the higher the potential energy. As the distance between the object and the charge source increases, the electric potential energy decreases.
5. Can electric potential energy be converted into other forms of energy?
Yes, electric potential energy can be converted into other forms of energy, such as kinetic energy or thermal energy, when the charged object moves or interacts with another object. This conversion of energy is the basis for many technological applications, such as batteries and electrical circuits.
