Electric Potential Energy vs. Potential
In summary, the potential energy of a system is a property of the system as a whole, while the potential is a property of each specific point in space. The potential energy per charge is what we use to measure potential energy, and the potential energy per mass is what we use to measure gravitational potential. The potential energy of a system is the change in potential energy of the system when you put a charge, q, at a specific point.
schaefera
208
Hey all.
I have a question regarding potential vs. potential energy.
Basically, from what I can tell, the potential energy is a property of the system as a whole (it has a single value in any given situation) while the potential is a property of each specific point in space.
Would this be like saying that the potential and any point is equal to the potential energy the system WOULD have if you placed a charge of charge q at that point?
Why then do we deal with both quantities... it seems to me like the potential is really just potential energy except that we are dividing out the charge of a "hypothetical point charge" that we could have added to the system, but then take out to make the math simpler.
Is this an ok way to think about it-- that the potential energy WOULD be what the potential is multiplied by a charge placed at that point... that would be a seemingly redundant definition, though.
Thanks in advance for clarification!
hi schaefera! :smile:
electric potential is potential energy per charge
(similarly, gravitational potential is potential energy per mass)
same reason we sometimes use gravitational potential … it makes the calculations easier
So is it like I was describing, then? How, if we placed an actual charge there then clearly the potential energy of the system (for which there is only one value) would change... but we divide out by that test charge so as to make it not really matter-- make it the potential energy per charge?
sorry, i didn't (and don't) understand that :confused:
(a "test charge" is assumed to be so small that it doesn't affect the system … is that what you meant?)
Ok, so potential energy is a property of the system, but potential changes from point to point. This would imply to me that a way to think about finding potential is as follows: imagine placing a charge, q, at the point you are interested in. This will mean you put positive (or negative or zero) work into the system to move that point to your location. Thus, the increase in potential energy of the entire system has changed in accordance with that work. But the potential doesn't depend on the charge, q, so you remove that from you equation (in essence dividing it out from the change in potential energy). Is that how to think about a very detailed process of measuring the potential at any given point?
I guess it's confusing me because when talking about potential energy in gravitation, for example in dropping a ball to the Earth's surface, we never really worried about potential (just potential energy). We didn't really think of the work required to assemble the system in gravitational cases like this, so I'm trying to think up a new way of imagining how to find potential for electricity.
Maybe it's something like that?
This sure is one fun question to think about!
Ah hah! I know what's confusing me:
If potential is merely potential energy divided by q, why can potential energy have one value for the whole system with potential varying from point to point?
because you turn it the other way up …
potential energy = potential times charge (at each point (x,y,z))
so total potential energy = ∫∫∫ potential times charge-density dxdydz …
the total PE is the integral of the potential times the charge-density :wink:
(like total gravitational PE is the integral of the potential times the ordinary density)
Ohhhh! So you integrate over potential-- which varies with location-- to get potential energy-- which is one number, namely the value of the integral. So at every point there is a potential which multiples a charge density?
Thank you for helping my understanding!
Related to Electric Potential Energy vs. Potential
1. What is the difference between electric potential energy and potential?
Electric potential energy is the amount of energy that a charged particle possesses due to its position in an electric field. It is a scalar quantity that is dependent on the charge of the particle, the strength of the electric field, and the distance between the particle and the source of the field. On the other hand, potential is a measure of the potential energy per unit charge at a specific point in the electric field. It is also a scalar quantity, but it is not dependent on the charge of the particle.
2. How are electric potential energy and potential related?
Electric potential energy and potential are directly proportional to each other. This means that as the electric potential energy increases, the potential also increases and vice versa. This relationship is described by the equation: potential energy = charge x potential.
3. Can electric potential energy be negative?
Yes, electric potential energy can be negative. This occurs when the charged particle and the source of the electric field have opposite charges. In this case, the electric potential energy is negative because the work done by the electric field to bring the particle closer to the source is negative.
4. How is electric potential energy calculated?
The electric potential energy of a charged particle in an electric field can be calculated using the equation: potential energy = (charge x electric potential difference) + (charge x distance). The electric potential difference is the difference in potential between the starting and ending points of the particle, and the distance is the distance between these two points.
5. What are some real-life examples of electric potential energy?
Some real-life examples of electric potential energy include lightning strikes, batteries, and electric circuits. In a lightning strike, the buildup of electric potential energy between clouds and the ground is released in the form of a powerful bolt of lightning. In batteries, chemical reactions create a potential difference, which can be converted into electrical energy. In electric circuits, the potential difference between the positive and negative terminals of a battery allows for the flow of electricity.
