Electric Potential expression at point P
In summary, the formula for calculating electric potential at a point P is V = kQ/r, where V is the electric potential, k is the Coulomb's constant, Q is the charge creating the electric field, and r is the distance from the charge to the point P. The unit used to measure electric potential is volts (V). The electric potential at point P is inversely proportional to the distance from the point charge, meaning it decreases as the distance increases. The electric potential at point P can be negative if the charge creating the electric field is negative or if the point P is located in the opposite direction of the electric field. It can also be zero if the point P is located at an infinite distance from the charge or on
ashworcp
The plastic rod of length L shown in the figure has the nonuniform linear charge distribution λ =cx, where c is a positive constant. Find an expression for the electric potential at point P on the y-axis, a distance y from one end of the rod.
V = ?
V = 1/4πϵ
There is no figure in the problem.
FAQ: Electric Potential expression at point P
What is the formula for calculating electric potential at a point P?
The formula for calculating electric potential at a point P is V = kQ/r, where V is the electric potential, k is the Coulomb's constant, Q is the charge creating the electric field, and r is the distance from the charge to the point P.
What unit is used to measure electric potential?
How does the distance from a point charge affect the electric potential at point P?
The electric potential at point P is inversely proportional to the distance from the point charge. This means that the electric potential decreases as the distance from the point charge increases.
Can the electric potential at point P be negative?
Yes, the electric potential at point P can be negative if the charge creating the electric field is negative. It can also be negative if the point P is located in the opposite direction of the electric field.
Can the electric potential at point P be zero?
Yes, the electric potential at point P can be zero if the point P is located at an infinite distance from the charge creating the electric field. It can also be zero if the point P is located on an equipotential surface, where the electric potential is constant.
