Electric Potential find the potential at its center
lemaire
A thin plastic rod 15 cm long carries 4.2 nC distributed uniformly over its length.
(a) If the rod is bent into a ring, find the potential at its center.
(b) If the rod is bent into a semicircle, find the potential at the center (i.e., at the center of the circle of which the semicircle is part).
V = KQ/r potential at a point.
when bending the rod, how to find the distance r.
If a 15 cm rod is bent into a circle, then it will be a circle 15 cm in circumference. What is the radius of a 15 cm circumference circle?
Circumference=2(pi)r
It's given a gas of particles all identical which has T fixed and spin S. Let's the density of orbital states and for , zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate and we have...
