Electric potential generated by a electric loop
Another approach is to use the potential generated by moving particles, which is always positive, and is different from the first approach. The question is, which one is correct? In summary, the conversation discusses two different approaches for calculating the electric potential generated by a loop and questions which one is correct.
Tianwu Zang
Hi all,
What is the potential generated by a electric loop? I have found two ways to sovle the problem. One is since the charge density does not change with time, we can write it as
[tex]\phi(\vec{r_{0}})[/tex]=[tex]\oint\frac{\rho_{static}}{|\vec{r}-\vec{r_{0}}|}d\vec{l}[/tex]. But what is [tex]\rho[/tex] in this loop? Is it should be zero? If the charge density is zero, than the electric potential is zero everywhere, thus there is no electric field. Is it true?
Another approach is that using the potential generated by the moving particles, therefore
[tex]\phi(\vec{r_{0}})[/tex]=[tex]\oint\frac{\rho_{total}}{|\vec{r}-\vec{r_{0}}|\times(1-\frac{\vec{v}\bullet(\vec{r}-\vec{r_{0}})}{c|\vec{r}-\vec{r_{0}}|})}d\vec{l}[/tex]. And this equation, which is always positive, is totally different from the former one, so which one is correct?
Thanks.
"We" cannot write the electric potential as$$\phi(\vec{r_{0}})=\oint\frac{\rho_{static}}{|\vec{r}-\vec{r_{0}}|}d\vec{l}$$because the electric potential is a scalar quantity and your expression implies that it s a vector quantity.
FAQ: Electric potential generated by a electric loop
What is electric potential?
Electric potential is a measure of the potential energy per unit charge at a given point in an electric field. It is often described as the amount of work required to move a unit charge from a reference point to a specific location in the electric field.
How is electric potential generated by an electric loop?
Electric potential is generated by an electric loop through the flow of electric current. As the electric current travels through the loop, it creates a magnetic field, which in turn generates an electric potential. This potential is then measured in volts.
What is an electric loop?
An electric loop, also known as an electric circuit, is a closed path or loop through which electric current can flow. It is typically made up of a power source, conductors, and resistors, and is used to power various electrical devices and systems.
How does the size and shape of an electric loop affect the electric potential generated?
The size and shape of an electric loop can affect the electric potential generated in several ways. A larger loop will generally have a higher potential due to the increased surface area for electric current to flow. Additionally, the shape of the loop can impact the distribution of electric potential, with more complex shapes often resulting in varying potential levels along the loop.
Can the direction of an electric loop affect the electric potential generated?
Yes, the direction of an electric loop can affect the electric potential generated. This is because the direction of the electric current within the loop can change the direction of the magnetic field, which in turn alters the electric potential. This is seen in devices such as motors, where the direction of the electric loop is crucial for the desired movement of the motor.
