Electric Potential in Region z>0 Using Method of Images
In summary, the conversation discusses the application of the method of images to obtain the electric potential in a specific region for an infinite grounded conducting plane with a point charge. The conversation then explores modifications to this method for a non-grounded plane at a potential V0 and discusses the concept of image charges and their corresponding boundary conditions. The potential can be shifted by a constant without affecting the partial differential equation it has to fulfill. However, specifying the potential at infinity can result in different solutions, with one corresponding to a constant field and the other to a linear potential.
Telemachus
835
30
Hi there. The example to obtain the electric potential in the region z>0 by the method of images for a infinite grounded conducting plane, with a point charge q located at a distance d is a typical example of the application of the method of images.
If we consider that the plane is located in the xy plane, at z=0, and the charge at z=d, we must fulfill the boundary conditions:
1. ##V=0## when ##z=0##
2. ##V \rightarrow 0## far from the charge, that is for ##x^2+y^2+z^2>>d^2##.
So locating the image charge at z=-d one can get the desired potential for the region of space of interest, being:
##\displaystyle V(x,y,z)=\frac{1}{4\pi \epsilon_0}\left [ \frac{q}{\sqrt{x^2+y^2+(z-d)^2}}-\frac{q}{\sqrt{x^2+y^2+(z+d)^2}} \right ]##
Now, if the plane is not grounded, how should I modify this to set it, let's say at a potential ##V_0##?
I thought that one posibility would be to use an other image distribution, an infinite charged plane parallel to the conducting plane, at a position ##-z_0## such that ##\frac {\sigma}{2\epsilon_0}z_0=V_0##, where ##\sigma## is the charge per unit area in the charged plane. I think that another possibility would be just to put the charges over the conducting plane. Now the induced charges will be, ofcourse infinite. And the electric field will be the sum of the images plus the real charge in the region z>0.
So, what I should have would be something like:
##\displaystyle V'(x,y,z)=\frac{1}{4\pi \epsilon_0}\left [ \frac{q}{\sqrt{x^2+y^2+(z-d)^2}}-\frac{q}{\sqrt{x^2+y^2+(z+d)^2}} \right ]+\frac{V_0}{z_0}(z_0-z)##
The potential due to the infinite charged plane should grow with z, and at the same time it should meet the condition of V(x,y,z=0)=V_0. I'm having trouble with where I'm puting the origin of the potential with respect to the two planes I'm considering.
Thanks in advance.
Hint: You can shift the potential by a constant without affecting the partial differential equation it has to fulfill (the poisson equation).
Wait, so you're just saying to add the potential [itex]V_0[/itex] to the expression for [itex]V[/itex], and it'll all be ok? That seems weird to me- mostly because it won't change the potential difference between the plate and the point charge, which is what I think Telemachus wants to see; what happens when the charge [itex]q[/itex] is above the plate but the plate isn't at zero potential.
Or maybe I just didn't get your hint at all :confused:
I've always had trouble with the whole image charges concept, so I'm quite interested in the answer to this question (don't think I can help- especially not at around 5 in the morning).
Likes Telemachus
Yes, this is exactly what I am saying. What makes you think the potential difference between the plate and the charge (which is infinite, but anyway ...) should change? The potential is defined up to an arbitrary constant so this still satisfies the Poisson equation. If you want to be more specific you will have to define the potential at infinity. Specifying it as anything other than V0 will just make your computations more involved while not really changing the field.
Oh wow right, infinite potential at the point charge.. Quite stupid of me, sorry about that. Thanks for clarifying.
I thought of that, but I don't think that it's correct. I think I must use the expression I've found, and considere both images in the region of space of interest, the one that generates the potential difference at z=0, and the mirror image for the point charge. The potential I obtain isn't the same, note that the potential due to the infinite charged plane increases linearly with z. So I've got two possible answers to get a solution that fulfills the boundary conditions, but the one I obtain by just adding a constant doesn't change anything from a physical point of view. The electric field (which we may considere a physical entity) wouldn't change, and in this case I think that isn't quite right.
Yes, the two correspond to different solutions and the difference is the boundary conditions that you put at infinity. The linear solution requires an infinite potential at infinity and would correspond to a constant field far away from the point charge. The solution I proposed is what you get if you want the field to go to zero at infinity. So the question is, which is being asked for?
Note that the boundary condition ##V \to 0## as ##r \to \infty## is impossible to satisfy in all directions since you have an infinite plane with a non-zero potential.
Edit: Note that potentials are only defined up to a constant. I could therefore just redefine the potential at the plane to be zero without changing the physics assuming I take this into account in all the boundary conditions. This does not, and should not, change the physics.
Likes Telemachus
I haven't thought on the boundary conditions I should have, I just thought of the plane as being charged with respect to a reference, and I think that must imply that there are charges over the plane (so the force exerted over the real charge wouldn't be the same in both cases, just adding a constant won't change the force). The solution you proposed wouldn't meet the boundary contition at infinity neither, it would set it at ##V_0##.
Anyway, I think your observation was fine.
Assuming that the fields vanish is quite common in physical situations and is what more closely corresponds to the original question. If I had put a question like that to my students, it would have been my intended meaning. That being said, if there is nothing specified, then the boundary condition at infinity could also be a constant field. In fact, the free space solution also allows a linear potential, corresponding to a constant field in all of space.
Likes Telemachus
Yes, you are right, thank you Orodruin, I think this discussion has been enriching and clarifying. There are physical differences in both situations. For example, the induced charges in my case would be infinite, while if I've used your proposal, the induced charges would be the same in both cases. I think its interesting to mention it.
so if I understood this whole discussion correctly, the only thing that would change when the infinite plate is grounded is the magnitude of the image charges?
I was reviewing my E&M and got stuck on this problem about two infinite grounded planes with point charge in the middle. It's easy to find the an expression for force when they're grounded, but then it asked what would happen if the metal plates were not grounded and I wasn't sure, so I tried to google it and stumbled upon this forum.
Likes Telemachus
The only relevant thing for the field is the potential difference between the plates. Unless you put a potential difference between the plates, the situation will be exactly equivalent to that of the grounded plates.
Likes Telemachus
Related to Electric Potential in Region z>0 Using Method of Images
1. What is the method of images and how is it used to calculate electric potential in region z>0?
The method of images is a technique used in electrostatics to solve problems involving charged particles and conductors. In the case of calculating electric potential in region z>0, the method of images involves creating a mirror image of the given charge distribution across a plane of symmetry, and then using the principle of superposition to calculate the total potential at a point in the region.
2. Can the method of images be used for any charge distribution in region z>0?
Yes, the method of images can be used for any charge distribution in region z>0 as long as there is a plane of symmetry present. This means that the charge distribution must have a reflection symmetry across a plane perpendicular to the z-axis.
3. What are the advantages of using the method of images to calculate electric potential?
The method of images is advantageous because it simplifies complex charge distributions into simpler, symmetric distributions. This makes it easier to calculate the electric potential at a point in the region z>0. Additionally, the method of images can be used to calculate the potential of an infinite plane or line of charge, which are commonly encountered in electrostatics problems.
4. Are there any limitations or drawbacks to using the method of images?
One limitation of the method of images is that it can only be used for static or stationary charge distributions. It cannot be used for time-varying or moving charge distributions. Additionally, the method of images assumes that the charges are point charges, which may not always be the case in real-world situations.
5. How does the method of images relate to the concept of boundary conditions?
The method of images is based on the concept of boundary conditions, specifically the boundary conditions for electric potential. These conditions state that the potential must be continuous and the electric field must be perpendicular to the surface of a conductor at the boundary. The method of images utilizes these boundary conditions to determine the appropriate charge distribution needed to satisfy them and calculate the electric potential in region z>0.
