prodo123
- 17
- 4
Q1: There are two concentric spherical shells with radii ##R_1## and ##R_2## and charges ##q_1## and ##q_2## uniformly distributed across their surfaces. What is the electric potential at the center of the shells?
Q2: There is an infinitely long hollow cylinder of linear charge density ##\lambda## and radius ##R##. What is the potential difference ##\Delta V## between the surface of the shell and a radius ##R'## inside the cylinder?
##\vec E = -\nabla V##
##\oint \vec E \cdot d\vec A = \frac{Q\text{encl}}{\epsilon_0}## (Gauss's Law)
##V=\frac{q}{4\pi \epsilon_0 r}##
Starting with Q2, Gauss's Law using a cylinder as the Gaussian surface shows there is no enclosed charge; ##\vec E = \vec 0##. Because ##\vec E = -\nabla V##, one can conclude that ##V=0## between ##R'## to ##R##. This is the given (and found) answer for Q2.
In a similar way, there is no enclosable charge for all points inside the two spherical shells in Q1. By the same logic as Q2, it would seem ##\vec E=0=-\nabla V## and there would be no electric potential at the center of the shells.
However, Gauss's Law cannot be applied to a point or line since the Gaussian surface has area ##A=0## and Gauss's Law reduces to ##0=0##. Therefore, one cannot find the electric field at the center of the sphere, and ##\vec E = -\nabla V## cannot be used.
Since the center of the shells are at a constant distance ##R_1## and ##R_2##, the electric potential can be found by:
##V=\frac{q_1}{4\pi \epsilon_0 R_1} + \frac{q_2}{4\pi \epsilon_0 R_2}##
which is the given answer for Q1. (One needs to integrate the charge density across a spherical area, which ultimately reduces to the answer above)
This result (i.e. textbook answers) seems to show some weird results:
- The electric field and potential are zero for all positions inside a closed area of charge and nonzero at the symmetrical center or axis.
- The graphs of the field magnitude and electric potential are discontinuous at the center.
- If this is true, the electric field vector there has no defined direction...? (or is undefined since the equation is discontinuous)
- In Q2, the electric field and potential should be nonzero along the axis of the cylinder and zero for all spaces between the axis and the cylinder wall.
I'm somewhat confused because the two questions seem to contradict each other. Is my logic correct in interpreting the answers?
