Trifis
- 167
- 1
Consider a homogeneously charged, infinitely long, straight wire of finite radius R. Determine the potential [itex]\phi[/itex](r) of the wire for r ≤ R and for r ≥ R. You must use the Poisson-Equation!
Δφ(r) = -ρ(r)/ε ⇔ [itex]\frac{1}{r}[/itex][itex]\frac{∂}{∂r}[/itex](r[itex]\frac{∂φ}{∂r}[/itex]) + [itex]\frac{1}{r^{2}}[/itex][itex]\frac{∂^{2}φ}{∂θ^{2}}[/itex] + [itex]\frac{∂^{2}φ}{∂z^{2}}[/itex] = -ρ[itex]_{0}[/itex]/ε
Ok first of all, I'm really frustrated, cause this problem is a two-minutes work using the Gauss's Law and I'm stuck for an hour
This problem should be really trivial, cause the partial DE could be reduced due to symmetry (the electric field must have only radial dependency) to the following ordinary DE :
[itex]\frac{1}{r}[/itex][itex]\frac{d}{dr}[/itex](r[itex]\frac{dφ}{dr}[/itex]) = -ρ[itex]_{0}[/itex]/ε , with the solution : φ(r) = -[itex]\frac{ρ [itex]_{0}[/itex]r^{2}}{4ε}[/itex] + C[itex]_{1}[/itex]ln(r) + C[itex]_{2}[/itex]
The problem is I've no idea how I could calculate C[itex]_{1}[/itex] and C[itex]_{2}[/itex] for the two areas r ≤ R and r ≥ R ! I've thought of integrating with upper and lower bounds instead of indefinitely but to no avail...
