fluidistic
- 262
I would like to calculate the electric potential in all the space in the following set up:
Conductor sphere of radius a whose surface is kept at a zero potential. 1 point charge ##q_1## at distance ##d_1## from the center of the sphere. 1 point charge ##q_2## at a distance ##d_2## from the center of the sphere.
There's the relation ##d_1>d_2>a##
The set up is such that if you use a Cartesian coordinate system with x and y-axis centered in the center of the sphere, q1 is at ##(0,d_1)## and q2 is at ##(d_2,0)##.
Green function for a sphere: ##G(x,x')=\frac{1}{|x-x'|}-\frac{a}{|x'|x-\frac{a^2x'}{|x'|^2}}##.
Then, the potential is given by ##\Phi (x)= \int _ \Omega G(x,x')\rho (x')d^3x'+\frac{1}{4\pi} \oint _{\partial \Omega} \frac{\partial G (x,x')}{\partial n' }V(x')da'##.
I'll use spherical coordinates ##(r, \theta , \phi )##.
I want to write the Green function in spherical coordinate and also the charges distributions.
First I notice that ##V(x')=0##, because that's the potential over the sphere. So that simplifies greatly the potential expression.
I'm left with ##\Phi (x)= \int _ \Omega G(x,x')\rho (x')d^3x'## where I must write all under spherical coordinates. I think I've ##G(x,x')## under spherical coordinate on my sheet.
Now I'm unsure about ##\rho (x')##. The first charge distribution would be... ##\rho _1 (\vec x )=q_1 \frac{\delta (\theta ) }{r} \delta (r-d_1 ) \frac{\delta (\phi)}{r \sin \theta }##. I'm unsure mostly about the Dirac's delta of the phi coordinate. Because that angle is not definied for spherical coordinate system, here I took it as the charge is at phi=0, but it could have been any other number, hence my doubt.
For the 2nd charge, ##\rho _2 (\vec x ) =q_2 \frac{\delta (\theta - \frac{\pi}{2}) \delta (r-d_2) \delta (\phi) }{r^2 \sin \theta }##.
Here I'm unsure again. I'm doubting whether the surface of the sphere gets polarized, in which case I guess I'd have to include a ##\rho _3 (\vec x )## that contributes as a source. But since V=0, I'm not really sure that it gets polarized though I believe it really does.
This means I'd have to also calculate ##\sigma _{\text{induced }}## at the surface of the sphere, but I don't even have the potential in all the space nor the electric field.
So I don't know how to continue further. Any help is appreciated.
P.S.:I'm using cgs system of units where the Coulomb constant is worth k=1 while Jackson's and Griffiths use SI units where ##k=\frac{1}{4\pi \varepsilon _0}##.
