Electric Potential (Why the opposite sign?)
Thanks for the help guys. In summary, two large, parallel, conducting plates with charges of equal magnitude and opposite sign are 12 cm apart. An electrostatic force of 3.9 \times {10}^{-15} N is acting on an electron placed between the plates. The electric field at the position of the electron is 2.4 \times {10}^{4} N/C. The potential difference between the plates is 2.9 \times {10}^{3} V, with the negative plate on top and the positive plate on the bottom. The direction of the electric field is from the positive plate to the negative plate, and the direction of the potential difference is from the negative plate to the
PFStudent
170
Two large, parallel, conducting plates are 12 cm apart and have charges of equal magnitude and opposite sign on their facing surfaces. An electrostatic force of [tex]3.9 \times {10}^{-15} N[/tex] acts on an electron placed anywhere between the two plates. (Neglect fringing.)
(a) Find the electric field at the position of the electron.
(b) What is the potential difference between the plates?
[tex]
{\vec{E}}_{p1} = {\frac{\vec{F}_{21}}{q_{2}}}
[/tex]
[tex]
{E_{p1}} = {\frac{|\vec{F}_{21}|}{|q_{2}|}}
[/tex]
[tex]
{E} = {-{\frac{\Delta{V}}{\Delta{r}}}}
[/tex]
At first I thought this was a pretty straight-forward problem and got part (a) right but did not understand why part (b) was wrong.
(a)
[tex]
{F_{21}} = 3.9 \times {10}^{-15} N
[/tex]
[tex]
q_{2} = -e
[/tex]
[tex]
{E_{p1}} = {\frac{|\vec{F_{21}}|}{|q_{2}|}}
[/tex]
sig. fig. [itex]\equiv[/itex] 2
[tex]
{E_{p1}} = 2.4 \times {10}^{4} N/C
[/tex]
(b)
[tex]
\Delta{r} = 0.12{\textcolor[rgb]{1.00,1.00,1.00}{.}}m
[/tex]
[tex]
[/tex]
[tex]
{\Delta{V}} = {-}{\Delta{r}}}}{E}
[/tex]
[tex]
{\Delta{V}} = -2.9 \times {10}^{3}{\textcolor[rgb]{1.00,1.00,1.00}{.}}V
[/tex]
However, the book answer is: [tex]2.9 \times {10}^{3}{\textcolor[rgb]{1.00,1.00,1.00}{.}}V[/tex].
So, why is the book's answer positive?
Any help is appreciated.
Thanks,
-PFStudent
The key is actually that you found the magnitude of electric field in part one. For the second part you need to use the vector of the electric field, and get the direction right. The only way I know how to tackle it is with calculus, but it is basic so don't freak out.
[tex]V = - \int_a^b \mathbf{E} \cdot d\matbf{l}[/tex]
which simplifies (the first one was just for my purposes) to
[tex] V = - \int_0^{.12} \mathbf{E} \cdot dr\hat{r}[/tex]
so this is the key step, the one you messed up. If you have your plates drawn on your paper so that the positive one is on top and the negative one is on the bottom the electric field is pointing down. I am integrating in the upwards hat direction, from the negative plate to the positive plate because that is the convention (integrate from negative to positive). So there is an extra minus sign introduced to flip the direction. Hopefully that makes since.
[tex] V = - \int_0^{.12} -E dr[/tex]
so then
[tex] V = E * r[/tex]
then evaluate with r = .12 and E = your E.
Just as an aid to remembering the minus sign:
Keep in mind that the direction of electric fields is defined as the direction that a positive charge carrier will accelerate. Since the potential is the negative integral (or antiderivative) of the electric field*, this means positive charge carriers accelerate from higher to lower potentials. This is consistent with the conservation of mechanical energy, in which kinetic energy increases while (electric) potential energy decreases. Since V = U/q , electric potential energy and electric potential both decrease for accelerating positive charges.
*This comes from the work-potential energy theorem, which is related to the conservation of mechanical energy discussed a little further on in the paragraph.
Just the reverse will be the case for electrons and other negative charge carriers. They run "backwards up" the electric field arrows. Since they must also observe conservation of mechanical energy, they will accelerate in the direction of decreasing potential energy, but that now means they accelerate from lower to higher electric potential.
I harp on this point with my students because people are endlessly victimized on this point on exam questions (especially multiple-choice questions!)...
P.S. I have to say, though, that the statement of the problem is a bit sloppy: it says nothing about which direction we are to take as positive, so it's not clear what the orientation of the field is to be taken as. I suspect they are just giving the magnitude of the potential difference as the answer...
Hey,
Thanks for the replies Mindscrape and dynamicsolo.
How I ended up approaching this problem was remembering that when defining the direction of an Electric Field we always use a positive test charge. So, although the charge is negative; I note the electric field lines leave from the postive plate (say on the right) to the negative plate (say on the left) as they normally would. That is, electric field lines leave from the positive plate and terminate on the negative plate. So, although the charge between the two plates is negative the electric field should still point to the left, is that right?
The displacement vector I reasoned points to the right because that is the direction it would accelerate (towards the postive plate since the charge is negative).
Now,
[tex]
{\Delta{V}_{p}} = {-}{\int_{r_{0}}^{r_{1}}}{\vec{E}_{p1}(r)}{\cdot}{d{\vec{r}}}
[/tex]
[tex]
{\Delta{V}_{p}} = {-}{\int_{r_{0}}^{r_{1}}}{|\vec{E}_{p1}(r)|}{|d{\vec{r}}|}{cos\theta}
[/tex]
Since, the vectors are in opposite direction the angle is 180 degrees.
[tex]
{\Delta{V}_{p}} = {|\vec{E}_{p1}(x)|}{\int_{x_{0}}^{x_{1}}}{d{{x}}}
[/tex]
Also, [itex]{d{x}} > 0[/itex] and [tex]{|\vec{E}_{p1}(x)|} = {{E}_{p1}}[/tex]
[tex]
{\Delta{V}_{p}} = {({E}_{p1})}{\Delta{x}}
[/tex]
[tex]
{\Delta{V}_{p}} = {\left(\frac{|\vec{F}_{21}|}{|(-e)|}\right)}{\Delta{x}}
[/tex]
[tex]
{\Delta{V}_{p}} = {\frac{|\vec{F}_{21}|}{e}}{\Delta{x}}
[/tex]
[tex]
{\Delta{V}_{p}} = {\frac{{|\vec{F}_{21}|}{\Delta{x}}}{e}}
[/tex]
[tex]
{\Delta{V}_{p}} = 2.9 \times {10}^{3} V
[/tex]
Thanks for posting the general form for the potential difference, I forgot I could use that.
so then
Yea, I think my work above was the approach you described except I integrated from left to right instead of bottom to top (same thing though, right?).
I was not sure what the convention was for the sign, but your explanation cleared it up a bit. Also, with regards to my approach above--was that the correct approach? Thanks.
Thanks for the help Mindscrape and dynamicsolo.
-PFStudent
Yep, it looks like you just forgot which direction the electric field went in (positive test charge is the convention), and your new work looks good. You can orient the plates however you feel like, top/bottom, left/right, bottom/top, right/left, angled, etc., as long as you get the vector directions right relative to the positive and negative plate.
when i try to look at the solution, it says "Physicsforums.com"
Related to Electric Potential (Why the opposite sign?)
1. What is electric potential?
Electric potential is the amount of energy that a charged particle has per unit charge at a given point in an electric field. It is also known as voltage and is measured in volts (V).
2. Why is electric potential defined as having an opposite sign to electric field?
This convention was established to simplify calculations and make them more consistent. By defining electric potential as having an opposite sign to electric field, the direction of the electric field will always be in the direction of decreasing potential. This simplifies the calculation of work done by the electric field on a charged particle.
3. How does electric potential affect the movement of charged particles?
Charged particles will move from areas of high potential to areas of low potential. This movement is caused by the electric field, which exerts a force on the charged particles. The magnitude and direction of the force depends on the charge of the particle and the electric field strength.
4. What is the difference between electric potential and electric potential energy?
Electric potential is a measure of the energy per unit charge at a given point, while electric potential energy is the potential energy that a charged particle has due to its position in an electric field. In other words, electric potential is a property of the electric field, while electric potential energy is a property of the charged particle.
5. How is electric potential related to electric potential difference?
Electric potential difference is the difference in electric potential between two points in an electric field. It is calculated by taking the difference in potential between the two points. In other words, it is a measure of the change in potential energy that a charged particle would experience when moving between the two points. Electric potential difference is also known as voltage.
