Electrical Attraction and Repulsion Related to Distance?
In summary, the conversation discusses the concept of attraction and repulsion between charged particles and neutral atoms. It is explained that there is no specific distance at which these phenomena occur, but rather they are continuous and the strength of the forces depends on the distance between the particles. The Lennard-Jones potential is mentioned as a way to understand the equilibrium point at which there is no net force between two atoms. The conversation concludes with the suggestion to do further research on the topic.
Nano-Passion
1,291
At what distance do unlike-charged ions stop attracting and start repelling? (I assume it can not keep attracting forever, unless outside force is applied to it).
At what distance do neutrally charged atoms start repelling each other? (Some momentum carrying them toward each other)
I've looked around and can't seem to find the answer to this. So in the premise that there is no answer:
Can we design an experiment to figure this out?
The answer is that you are looking at the phenomenon of electrostatic forces from a wrong perspective. There is no special distance at which attraction or repulsion sets in. They are continuous phenomena - like-charged ions always repel and unlikes always attract, regardless of the distance separating them. The role that distance plays is in affecting the strength of attraction/repulsion between them (specifically, the magnitude of the force is inversely proportional to the square of the distance between the particles).
You may wish to read up on Coulomb's law for more details.
I'm sorry, what I really mean is:
I don't think I'm aware of any such phenomenon. Unlike charges always attract no matter how far apart they are.
Please tell us where you got this information from as it is probably wrong (unless a verified research paper).
All in my head. Just some speculation and imagination.
You misunderstand me, what I am NOT saying is how far they have to be to repel. But how close do they have to get to start repelling.
Though as I ponder this phenomena I have realized that it probably is only exclusively reserved for neutrally charged atoms. Certainly at one point it stops following its' momentum and would collide with another object. We don't fall into our chair for a reason, but it repels us.
Just some speculation, I encourage you to correct or argue against me.
If unlikes never had a certain distance in which they repelled, they would ultimately coalesce. But certainly there is a force that keeps them from doing that. They don't attract indefinitely, but definitely at to a certain point. That distance is what I would like to figure out.
Feel free to correct my reasoning.
I get what you mean now. You are mainly interested in molecular dynamics, of the attraction and repulsion between atoms/molecules.
There is a potential that sums up the forces acting between two atoms, for instance, and it is known as the Lennard-Jones potential:
A simplistic explanation would be this: (for simplicity, let us consider the hydrogen atom) when two atoms are sufficiently far apart, the attraction between the nucleus of one and the electron of the other outweighs the electron-electron and nucleus-nucleus repulsion between the two atoms, and thus the net force is attractive. Beyond a certain point, the repulsive forces are stronger than the attractive forces, resulting in a net repulsive force. In between lies an equilibrium point at which potential energy of the system is at a minimum and there exists no net force between the two atoms.
The actual mechanics of the system are far more complicated, and you may wish to search for "Lennard-Jones potential" to read up further.
First I want to say thanks!
I did some research about it. This seems a little complicated as of right now, so far I've only learned classical mechanics in physics. So I feel a little bewildered. Do they teach us this in further physics classes?
FAQ: Electrical Attraction and Repulsion Related to Distance?
What is electrical attraction and repulsion?
Electrical attraction and repulsion refer to the fundamental forces that govern the interactions between charged particles. Attraction occurs when particles with opposite charges are pulled towards each other, while repulsion occurs when particles with the same charge push away from each other.
How is distance related to electrical attraction and repulsion?
The strength of electrical attraction and repulsion is inversely proportional to the square of the distance between the charged particles. This means that as the distance between particles decreases, the force of attraction or repulsion increases, and vice versa.
What is the role of electric fields in attraction and repulsion?
An electric field is a region in space where a charged particle experiences a force. In the case of electrical attraction and repulsion, the electric field is what causes the charged particles to either attract or repel each other.
How does the type of charge affect electrical attraction and repulsion?
The type of charge on the particles determines whether they will attract or repel each other. Oppositely charged particles (positive and negative) will attract, while particles with the same charge (both positive or both negative) will repel.
Can electrical attraction and repulsion occur between neutral objects?
No, electrical attraction and repulsion can only occur between charged particles. Neutral objects have an equal number of positive and negative charges, resulting in a net neutral charge and therefore no electrical attraction or repulsion.
