Electrical Charges and Attraction
In summary, charges repel and the -600VDC charge on the developing roller attracts the toner to the areas that have been exposed by the laser.
csfyp.mail
Hi, Pls I'd like to find out if 2 electrical charges (same charge but different voltages) would attract or repel. For example -600VDC and -100VDC.
I've always thought like charges repel and unlike charges attract. But I'm reading up on something that says the above would attract and become -600VDC.
Pls can someone explain why this is the case. Thanks
Welcome to the PF.
Charges do not have "voltage" as you have written. Charges are measured in units of Coulombs, and the electric fields that they cause will be the origin in changes in voltage (electrical potential).
Can you please copy the exact wording and figure from your textbook that have you confused?
Welcome to the PF.
This is it...
"A metallic roller called the developing roller inside an EP cartridge acquires a – 600VDC charge (called a bias voltage) from the HVPS. The toner sticks to this roller because there is a magnet located inside the roller and because of the electrostatic charges between the toner and the developing roller. While the developing roller rotates toward the photo-sensitive drum, the toner acquires the charge of the roller (–600VDC). When the toner comes between the developing roller and the photosensitive drum, the toner is attracted to the areas that have been exposed by the laser (because these areas have a lesser charge, –100VDC). The toner also is repelled from the unexposed areas (because they are at the same –600VDC charge, and like charges repel)."
EP - Electrophotographic
HVPS - High Voltage Power Supply
Thanks
csfyp.mail said:
This is it...
Thanks
Ah, that makes more sense. They are using the word "charged" in the context of charging up the capacitances of the roller and drum. The charge on a capacitor is Q = C*V, where C is the capacitance, and V is the voltage.
The explanation is not very precisely worded, unfortunately. The explanation at wikipedia.org is better:
http://en.wikipedia.org/wiki/Photocopier
Alright, Thanks.
FAQ: Electrical Charges and Attraction
What is an electrical charge?
An electrical charge is a fundamental property of matter that causes it to experience electromagnetic force. It can be either positive or negative and is measured in units of coulombs (C).
How do objects become charged?
Objects become charged when they gain or lose electrons. If an object gains electrons, it will become negatively charged. If it loses electrons, it will become positively charged. This can happen through friction, contact with other charged objects, or exposure to certain materials.
What is the law of attraction between electrical charges?
The law of attraction between electrical charges states that opposite charges attract each other, while like charges repel each other. This is due to the electromagnetic force between the charges. The strength of this force is directly proportional to the product of the charges and inversely proportional to the square of the distance between them.
Can electrical charges be separated?
Yes, electrical charges can be separated. This is known as charge separation and it occurs when an object gains or loses electrons, leaving one part of the object with a different charge than another part. This can happen naturally or through intentional means such as using a Van de Graaff generator.
How do conductors and insulators affect the flow of electrical charge?
Conductors, such as metals, allow for the easy flow of electrical charge due to their abundance of free electrons. Insulators, on the other hand, do not allow for the flow of electrical charge due to their tightly bound electrons. This is why metals are used for conducting electricity, while materials like rubber are used as insulators.
