In summary, the absolute value of the difference in electric potential between points A and B is either 5V, 4V, 3V, 1V, or 0V. The relevant equations to consider are E = qV and V = iR. There is no information given about current at points A or B, and it is unclear if the circuit can be simplified. Additionally, there is no information given about the current flowing through the 4k resistor connected to point A.
fuvest
In the following picture, the absolute value of the difference in electric potential, between points A and B is:
A)5V
B)4V
C)3V
D)1V
E)0V
E =qV
V = iR
I have no idea where to start on this one, just started my electric circuits unit so please bare with me. Any help would be appreciated, thanks and sorry for the inconvenience.
Is there any current at points A or B? If so why, if not, why not?
Likes cnh1995
Can you reduce the circuit in any way? In other words, are there 2 resistors in series that you can reduce to a single resistor, or are there 2 resistors in parallel that you can reduce to a single resistor? How much current is flowing through the 4k resistor that is connected to point A?
Related to Electrical Circuit Problem / Electric Potential Difference
1. What is an electrical circuit?
An electrical circuit is a closed loop through which electricity can flow. It is made up of various components, such as wires, resistors, capacitors, and batteries, connected together to form a complete path for the flow of electricity.
2. What is electric potential difference?
Electric potential difference, also known as voltage, is the difference in electric potential between two points in an electrical circuit. It is measured in volts and represents the amount of work needed to move a unit of electric charge between the two points.
3. How is electric potential difference calculated?
Electric potential difference is calculated by dividing the amount of work done (in joules) by the amount of charge (in coulombs) that is moved between two points in an electrical circuit. This can be represented by the equation V = W/Q, where V is the potential difference, W is the work done, and Q is the charge.
4. What is the relationship between electric potential difference and current?
The relationship between electric potential difference and current is described by Ohm's Law, which states that the current flowing through a conductor is directly proportional to the potential difference applied across it, and inversely proportional to the resistance of the conductor. In other words, as the potential difference increases, the current also increases, and vice versa.
5. How can I solve electrical circuit problems involving potential difference?
To solve electrical circuit problems involving potential difference, it is important to first identify all the components in the circuit and their respective values. Then, you can use the relevant equations, such as Ohm's Law and Kirchhoff's Laws, to calculate the potential difference at different points in the circuit. It is also helpful to draw a circuit diagram and use a systematic approach to solving the problem.
