Electrical circuits with resistors and variable voltage sources
In summary, the conversation discusses inconsistencies in data and attempts to determine the current through R2 in a circuit with varying voltage sources. The conversation also involves interpreting a graph and using circuit laws to solve for the value of R2. Ultimately, the value of R2 is determined to be 50 ohms based on data points at E2=10V and I1=0.2A. The difficulty of reading the graph is also mentioned.
Biker
416
52
The following picture illustrate how the current in the circuit changes when you change ##E_2##. Where slope 1 represents the current flowing through ##E_1## and slope 2 represents the current flowing through ##E2##
Usual circuit laws :P
I think there is inconsistency in data.
It didn't give me the direction in current so I assumed the following.
If we look at the point where ##E_2## is equal to 5 ( 5 , 0.1). There is only one possibility of both current being upward so it can flow in R2
So we now know that the positive values must be upward.
and we can easily know R2
## R_2 = \frac{E_2}{0.2} = \frac{5}{0.2} = 25 ##
Now if we look at point 10. We find that the current flowing in ##E_2## is 0.4 and upward
The current in ##E_1## is -0.2 which means 0.2 downward. We conclude that the current in ##R_2## is 0.2
## R_2 = \frac{E_2}{0.2} = \frac{10}{0.2}= 50 ##
Here is the inconsistency.
Biker said:
If we look at the point where E2 is equal to 5 ( 5 , 0.1).
That looks right - that the I2 current is 0.1 A for E2 = 5V. So what does that tell you about the value of R2?
Biker said:
R2=E2/0.2=5/0.2=25
Now it looks like you have assigned a different current (0.2 A) through R2 for the same E2 voltage of 5 V. How can that be?
Edit: Corrected "E1" to "E2" in second to last sentence.
That assumes the currents through E2 and R2 are the same.
Do you happen to have a better representation of the plot? It is very difficult to read, making me question my ability to read data points off of it accurately.
Well look at E2 0.4 A going to the node and 0.2 A coming out so the current in R2 must be equal to 0.2 A
TomHart said:
That looks right - that the I2 current is 0.1 A for E2 = 5V. So what does that tell you about the value of R2?Now it looks like you have assigned a different current (0.2 A) through R2 for the same E2 voltage of 5 V. How can that be?
Not sure what you mean :/, There are two points with the same current going through R2 but different voltages how come that can be true?
Nope, That is the only picture I got. :C sorry
I'm sorry. Once again my failure to read the problem statement carefully has caused my misunderstanding. I thought I1 and I2 were currents through R1 and R2. My mistake. Disregard what I said above.
I blame the picture, It is just unclear. :D
Likes TomHart
Thank you for your kindness, but the text was pretty easy to read - if only I had read it.. :)
Likes Biker
Biker said:
R2=E2/0.2=5/0.2=25
Biker, how did you come up with this equation? Are you reading I1 = I2 = 0.1 for E2 = 5 V and adding them to get the R2 current?
If 5V is the E2 voltage where I1 and I2 intersect, it looks like it could be somewhat less than 0.1 Amps, but it's hard to tell for sure.
Yes exactly, But the difference between 50 ohms and 25 ohms is pretty large, isn't it?
Yes, it is pretty large. But then again, if the intersection of I1 and I2 is really at E2 = 5V, I don't think it would be much of a stretch to say that those currents intersect at, say, 0.06 Amps, or even 0.05 Amps. Because if you look at the exact point where I2 is at 0.1 Amps, I1 appears to be some distance below it. The plot is just too vague to get very accurate information from it.
Likes Biker
Sorry, not following your logic. What specific data points are you making use of? From your original post, looks like you are using E2=5V, but in that case where are you getting the 0.4A from?
The sketch of the graphs is rather hard to read numbers off. I took the following:
E2=2, I1=.2
E2=10, I1=-.2
E2=4, I2=0
E2=10, I2=.42
and got R2=8.
I'm pretty sure what he's doing there is reading the I1 and I2 currents at E2 = 10 V.
At E2 = 10 V, I1 = -0.2 A and I2 = +0.4 A (from the plot).
The current into R2 has to be the sum of those two currents, or IR2 = -0.2 + 0.4 = 0.2 Amps.
Since the voltage across R2 is 10 V, R2 is calculated to be (10 V)/(0.2A) = 50 ohm
Another data point I was looking at is where I1 crosses the 0 line. I read E2 to be approximately 5.8 V, and I2 to be approximately 0.13 Amps. At that data point, I2 is equal to the current through R2. That would result in R2 = (5.8)/(0.14) = 44.6 ohm
Likes Biker
Ok, thanks.
The inconsistency lies in your use of a graphical aid. These are straight line plots, and you must not lose sight of that.
You decided the plots intersect at (5,0.1). Okay, we'll go with that.
You also decided another relevant point is at (10,0.4). Okay, we'll use that, too.
By those 2 points you have now fully defined these plots. If you need any more data points you must calculate them using geometry of a straight line. You should not attempt to read any further data off your scrappy thumbnail sketch because estimation errors in further readings will almost certainly give data not consistent with the plots defined by the 2 points you have already decided on.
If you had an accurate graph this "problem" would not arise. I put it in quotes because it is not really a problem at all. These are straight line plots, and you should appreciate the need to be rigorously consistent in treating the variables relationship at all times as linear.
A rather hard thread to read. It is hard to read the diagram which led to me misreading the problem - please always use an app like DocScanHD to present a less murky one.
epenguin said:
Seems to me the diagram has got to be wrong.
There is no way that the clockwise current through R2 can be negative. This current is just E2/R2, period. The current through R2 versus E2 graph must go through the origin.
Neither line represents the current through R2. They represent the currents through the sources.
Likes epenguin
:oops: I have deleted most of my post as I misunderstood the data and problem.
It seems to me that significant points are where the graphs cross the horizontal axis. This gives you the ratio of the E's and the ratio of the R's.
As far as I can see the in this complicated thread the OP has not given any general equation for the circuit to base an easy-to-follow reasoning on.
Related to Electrical circuits with resistors and variable voltage sources
1. What is an electrical circuit?
An electrical circuit is a path through which electricity can flow. It is made up of various components, such as resistors, variable voltage sources, and wires, that are connected in a closed loop.
2. What is a resistor and what is its purpose in an electrical circuit?
A resistor is an electronic component that limits the flow of electricity in a circuit. It is made of a material with high resistance, which means it resists the flow of electrons. This is useful in regulating the amount of current in a circuit and protecting other components from too much electricity.
3. How do variable voltage sources affect an electrical circuit?
Variable voltage sources, such as batteries or power supplies, provide a varying amount of voltage to an electrical circuit. This affects the flow of electricity and can impact the overall functioning of the circuit. By adjusting the voltage, you can control the amount of current flowing through the circuit and the brightness of components, such as light bulbs.
4. Can you explain Ohm's Law and how it relates to electrical circuits?
Ohm's Law states that the current (I) in an electrical circuit is equal to the voltage (V) divided by the resistance (R). This means that as the voltage increases, the current also increases, but as the resistance increases, the current decreases. This relationship is important in understanding and designing electrical circuits.
5. How do you calculate the total resistance in a series or parallel circuit?
In a series circuit, the total resistance is simply the sum of all the individual resistances. In a parallel circuit, the total resistance is calculated by taking the reciprocal of the sum of the reciprocals of each individual resistance. For example, if there are three resistors with values of 2, 4, and 6 ohms in parallel, the total resistance would be 1/(1/2 + 1/4 + 1/6) = 1.71 ohms.
