MHB Electrical Engineering Problem
The electric oven operates on a 110 V power line with a current of 1.0 A through its resistance heater. The thermal power produced by the heater is calculated using the formula P = I × E, resulting in 110 W. The discussion raises a question about the appropriateness of the problem being posted in the puzzle palace section. The calculation assumes 100% efficiency in converting electrical power to thermal power. The focus remains on the electrical engineering principles involved in determining the power output of the heater.
littlemac1
An electric oven is heated using electricity from a 110 V power line. The power line is connected to a resistance heater in the oven, and the current through the heater is found to be 1.0 A. Assuming the heater is 100% efficient in converting electrical power into thermal power, what is the thermal power produced by the thermal element?
Mathematics news on Phys.org
$P=I \cdot E = \left(1 \, \dfrac{C}{s}\right) \cdot \left(110 \, \dfrac{J}{C}\right) = 110 \, \dfrac{J}{s} = 110 \, W$
Just noticed this was posted in the puzzle palace ... am I missing something?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
