Electrical & Thermal Conductivities of Metals
In summary, electrical conductivity is the measure of how well a material can conduct electricity, typically measured in siemens per meter (S/m). Several factors can affect electrical conductivity, including temperature, impurities, and crystal structure. Thermal conductivity, on the other hand, is the measure of how well a material can conduct heat. Generally, materials that are good conductors of electricity are also good conductors of heat due to the transfer of energy through the movement of electrons.
Jimmy87
686
Hi, please could someone explain why silver is a better conductor than, say, copper. Is it due to the fact that it has more conduction electrons than copper? I can't seem to find a definitive answer online.
Thanks for any guidance offered.
The only way to "explain" this is to study the topic of Resistance in Metals. See this Wiki link, as a starter, and follow some of the items in the extensive list of references.
FAQ: Electrical & Thermal Conductivities of Metals
What is electrical conductivity?
Electrical conductivity is the measure of how well a material can conduct electricity. It is a physical property that determines how easily an electric current can pass through a material.
How is electrical conductivity measured?
Electrical conductivity is typically measured in units of siemens per meter (S/m). This is the reciprocal of electrical resistivity, which is measured in ohm-meters (Ω-m). The higher the value of electrical conductivity, the better the material is at conducting electricity.
What factors affect electrical conductivity?
Several factors can affect the electrical conductivity of a metal, including temperature, impurities, and crystal structure. Generally, metals have higher electrical conductivity at lower temperatures and when they are pure. The presence of impurities can also decrease the electrical conductivity of a metal.
What is thermal conductivity?
Thermal conductivity is the measure of how well a material can conduct heat. It is a physical property that determines how easily heat can be transferred through a material.
What is the relationship between electrical and thermal conductivity?
In general, materials that are good conductors of electricity are also good conductors of heat. This is because both electrical and thermal conductivity depend on the ability of a material to transfer energy through the movement of electrons.
