Electrically Inert Glue / Epoxy
  • Thread starter Gazzoo
  • Tags
    Epoxy
In summary, the conversation discusses the search for a super glue or epoxy that meets specific requirements, including being strong and durable, electrically inert, and easy to apply. The suggestion of using Electronics grade RTV or United Resin F-82 epoxy is mentioned, but it is important to consider the specific application to avoid reliability issues.
Gazzoo
Hi I'm looking for a super glue/epoxy that meets the following requirements:
1) when hardens is very very strong and durable and very resistance to abuse either mechanically or chemically etc
2) needs to be electrically inert, meaning that it should not be conductive or affect electronic circuitry in any way when applied on top of it, i.e. trace wires or chips etc...
3) be relatively easy and safe to apply
So does such a wonder glue exist?
Thanks
Electronics grade RTV is used commonly, but it is not all that strong.
We use United Resin F-82 epoxy for potting some of our products. It is quite hard and strong, and is compatible with electronics applications:
http://www.unitedresincorp.com/adhes1.htm
However, if you are potting electronics assemblies or components, there are some *very* important considerations, in order to avoid some reliability problems. Can you say more about the application?
for your question! Yes, there are several types of electrically inert glue or epoxy available on the market. These types of adhesives are specifically designed to have good electrical insulation properties, making them ideal for use in electronic applications. They are also very strong and durable, able to withstand various forms of abuse such as mechanical stress and exposure to chemicals. As for ease of application, most electrically inert glues and epoxies come in user-friendly packaging and are relatively easy and safe to apply. Some popular brands to consider are Loctite, 3M, and MG Chemicals. Be sure to carefully read the product labels and instructions to ensure the specific product meets your requirements. Best of luck with your search!
Related to Electrically Inert Glue / Epoxy
1. What is electrically inert glue/epoxy?
Electrically inert glue or epoxy is a type of adhesive material that does not conduct electricity. This means that it does not allow the flow of electric current through it, making it a suitable choice for use in electronic devices or circuits.
2. How does electrically inert glue/epoxy work?
Electrically inert glue or epoxy works by creating a strong bond between two surfaces, without allowing the passage of electricity. It is made up of insulating materials that prevent the flow of electric current, making it ideal for use in electrical applications.
3. What are the advantages of using electrically inert glue/epoxy?
There are several advantages of using electrically inert glue/epoxy. Firstly, it provides a strong and durable bond between surfaces. Secondly, it is resistant to electricity, making it safe to use in electronic devices. Additionally, it can withstand high temperatures and is resistant to chemicals, making it suitable for a variety of applications.
4. Can electrically inert glue/epoxy be used for all types of materials?
While electrically inert glue/epoxy is suitable for use on most materials, it may not be compatible with all types. It is important to check the compatibility of the glue/epoxy with the materials you are using it on to ensure a strong bond and avoid any potential damage.
5. How should electrically inert glue/epoxy be applied?
Electrically inert glue/epoxy should be applied in a thin and even layer on the surfaces that need to be bonded. It is important to follow the instructions provided by the manufacturer for the best results. Additionally, the surfaces should be clean and dry before applying the glue/epoxy for a strong bond.
