Electricity and magnetism. 2 questions
In summary, the first question discusses the energy stored in a capacitor discharging through a resistor and when it will be equal to half its initial value. The second question involves finding the charge of a particle moving in a uniform magnetic field, given its velocity and the magnetic force acting on it. The correct method for solving the problem is using the equation F=qvBsin(x), which results in a charge of 0.039C. The answer is confirmed by considering the charge in terms of current and comparing it to the force on a section of wire conducting the same current. The given mass in the question was not used in the solution.
Brewer
212
A couple of questions.
1. A capacitor of capacitance C is discharging through a resistor of resistance R. When will the energy stored be equal to half its initial value?
My logic went like this:
Energy in a capacitor (U) = Q^2/2C
so: Q = (2CU)^0.5
so therefore the charge when the energy is halved = (2C(U/2))^0.5 = (CU)^0.5
so from Q=Q0*exp(-t/RC)
(CU)^0.5 = (2CU)^0.5*exp(-t/RC)
(CU)^0.5 = (2)^0.5*(CU)^0.5*exp(-t/RC)
t = -RCln(1/(2)^0.5)
and this second question I don't really follow at all.
A particle of mass 6.0g moves at 4.0km/s in an xy plane, in a region of space with uniform magnetic field given by 5.0imT. At one instant when the particles velocity is directed at 37degrees counter clockwise from the positive x direction, the magnetic force on the particle is 0.48kN. What is the particles charge?
I had a go using: F=qvBsin(x) (where x = angle) and got a charge of 0.039C. Is this the right way to go about it? Seems quite a large charge to me.
Your answer to the first question is correct.
In the second, I think you are also right. I am assuming that i is the unit vector in the x direction and k is the unit vector in the z direction.
So, [itex]\vec F = q\vec v \times \vec B = qvsin(x)B\hat k = .48N \hat k[/itex]
[tex]\frac{F}{Bvsin(x)} = q [/itex]
Plugging in the numbers:
[tex]q = .48/(.005 * 4000 * .602) = .039 C[/tex]
Think of the moving charge in terms of current: dQ/dt = I where dQ is the charge strung out over 4 km. The current is .039 amps. So this is equivalent to the force on a 4 km section of wire conducting a current of .039 amps
AM
So I wasn't far off? Thats not bad. I was just concerned because a mass was given in the question,but I didn't seem to use one.
Ok. Thanks for that. Thats a bit more confidence in myself there!
FAQ: Electricity and magnetism. 2 questions
What is electricity?
Electricity is a form of energy that results from the movement of electrons. It can exist in two forms: static electricity, which is stationary and accumulated on an object, and current electricity, which is the flow of electrons through a conductor.
What is magnetism?
Magnetism is a physical phenomenon where objects exert attractive or repulsive forces on other materials. It is caused by the motion of electric charges, such as electrons, within the material.
