Electricity and Magnetism in a veloctiy selector
In summary, Lithium-6 ions with a mass 6 times that of a proton are accelerated by 2000 volts and passed through a velocity selector with a magnetic field of 0.020T. The ions follow a straight path through the selector and are then deflected onto a piece of film. The speed of the ions can be determined by using QV=(1/2)mv^2, which gives a velocity of 2.5*10^5m/s. The electric field in the velocity selector plates can be found using QvB=QE, which gives a value of 5.0*10^3N. However, this is off by a factor of ten and the correct answer is 5
Mr. Snookums
Lithium-6 ions (mass is 6x a proton mass) are charged Li+ ions (one extra proton). They are accelerated by 2000 volts and passed through a velocity selector with a magnetic field of 0.020T into the page. The ions follow a straight path through the selector and are then deflected onto a piece of film. The velocity selector plates are separated by 5.0cm.
Find:
a)the speed of the ions.
This is simple enough. QV=(1/2)mv^2, plug in the mass, charge and voltage and solve for velocity. This gives me 2.5*10^5m/s.
b)Electric field in the velocity selector plates.
QvB=QE, so E=Bv=(2.5*10^5)(0.020)=5.0*10^3N
However, I am off by a factor of ten. The answer is 5.0*10^4. Why is this?
c)Voltage in the velocity selector plates.
I know that the magnetic and electric forces are balanced. The electric force pushes down, the magnetic force pushes up.
For electric force, F=QE, so am I right in saying that F=QV/d?
Then I would get vB=V/d. This was my reasoning, but when I plug in the numbers, I do not get the correct answer. How would I go about solving this one?
Interesting I get the same answer as you do. Is the answer definitely correct? If yes we got to wait for someone more experienced!
a) Based on the given information, the speed of the ions can be calculated using the equation QV=(1/2)mv^2, where Q is the charge of the ion, V is the voltage, m is the mass of the ion, and v is the velocity. Plugging in the values, we get (1.6*10^-19C)(2000V)=(1/2)(6*1.67*10^-27kg)v^2. Solving for v, we get v=2.5*10^5m/s.
b) The electric field in the velocity selector plates can be calculated using the equation E=Bv, where B is the magnetic field and v is the velocity of the ions. Substituting the values, we get E=(0.020T)(2.5*10^5m/s)=5.0*10^4N/C.
c) The voltage in the velocity selector plates can be calculated using the equation V=Ed, where E is the electric field and d is the distance between the plates. Substituting the values, we get V=(5.0*10^4N/C)(0.05m)=2500V. The reason for the discrepancy in the calculations is most likely due to rounding errors or significant figures. It is important to carry out calculations with the appropriate number of significant figures to get accurate results.
FAQ: Electricity and Magnetism in a veloctiy selector
What is a velocity selector?
A velocity selector is a scientific instrument used to select particles with a specific velocity from a mixed stream of particles. It consists of two parallel plates with a uniform electric field and a perpendicular magnetic field.
How does a velocity selector work?
A velocity selector works by applying a force on particles with a specific velocity in a mixed stream of particles. The electric field exerts a force on charged particles, while the magnetic field deflects them. Only particles with a specific velocity that is perpendicular to both fields will pass through the selector without being deflected.
What is the purpose of using electricity and magnetism in a velocity selector?
The use of electricity and magnetism in a velocity selector allows for the precise selection of particles with a specific velocity. The electric field allows for the selection of charged particles, while the magnetic field allows for the selection of neutral particles based on their velocity.
What are some applications of a velocity selector?
Velocity selectors have various applications in scientific research, including in mass spectrometry, particle accelerators, and spectroscopy. They are also used in industrial processes, such as in the separation of isotopes and in the production of semiconductors.
What are some limitations of a velocity selector?
One limitation of a velocity selector is that it can only select particles with a specific velocity, and it cannot differentiate between particles with similar velocities. Additionally, it may be affected by external factors such as temperature and pressure, which can alter the velocity of particles in the stream.
